My IT Dept. just informed that they are upgrading my laptop to the following:
HP EliteBook 8540p Notebook PC Dual Core PN: NU486AVe |
Intel® Core™ i5-540M Processor; Mobile Intel QM57 Chipset , (2.53 GHz, 3 MB L3 cache, 1066 MHz FSB) Up-to 3.06 GHz |
NVIDIA NVS 5100 graphics with 1 GB dedicated DDR3 video mem |
Genuine Windows® 7 Professional 32 |
4GB 1333MHz DDR3 (2 DIMM) |
250GB 7200rpm SATA Hard Drive, HP ProtectTools Disk Encryption |
15.6-inch diagonal LED-backlit HD anti-glare (1366 x 768 res) |
HP Fingerprint Sensor |
Intel Centrino® Advanced-N 6200 (2x2) Intel Turbo Boost Tech |
Full-sized keyboard and enhanced dual pointing devices |
DVD+/-RW SuperMulti DL LightScribe Drive |
8-Cell Limited 3 year warranty, 3 Yr Warranty |
90W AC Adapter
I'm coming from a Dell Latitude D820 with 3 GB of RAM. Will the new HP be sufficient to run AutoCAD Map 2010, AutoCAD Raster Design 2010 and AutoCAD LT 2010 without any significant slow down? Thanks for your thoughts.
Jody in NH |
2 things stand out to me.
1. The windows 7 32 is the wrong os - it needs to be 64 bit, to handle ram over 4 gig. I know the system says you'll get 4 g installed, but the 32 bit os won't allow access to all of it, and you'll have problems with acad software. If you can get them to go to 8gigs you'd be better off. Also, most of adsk's new products are 64 bit (they are available as 32bit, but you're heading backwards, not forwards.
2. The laptop is too small. You REALLY NEED a 17 min monitor size to do any real work with today's adask projects. Even minor stuff, the program takes up so much space with menus, you'll spend most of your time panning & zooming.
Reid
2 Questions. Why 32 bit Windows? Why NVS videocard? LT will work fine as spec'ed but I wouldn't get an NVS videocard and I would get 64 bit to use your full 4 gig memory plus leave the option to upgrade down the road. Usability of extra memory certainly couldn't hurt plus th i5 is a good but not great chip. Certainly better than anything other than an i7. Windows 7 is slower than XP, so the extra memory is needed to make up the difference.
In addition to the above, they are also hobbling you with a Centrino chipset: great for casual users that spend more time in MSWord and surfing that AutoCAD. Is that your usage pattern? They seem to be buying you a low end unit.
Dean, I think you are off the mark on Centrino chipsets. The Centrino concept initially was Intel sells the manufacturer certain parts that are designed by Intel to work together (LOL) and they get to put the Centrino logo on the laptop.
Now it simply means that you are getting an Intel WIFI and/or WIMAX card.
Intel Centrino Wireless
Intel Centrino Wireless is the brand for Intel Wi-Fi and WiMAX adapters. The product line includes:
in addition to what others have said re get 64bit does it need to be a laptop?
unless you really need to be mobile you would be better of getting a desk top as you get more value for your money......its amazing how many people you see in offices today using laptops but who spend 95% of their time working at their desks comlaining that the laptop is to slow or the screen is to small.....
A lot of places push lapotops since space is limited working in cubicles and IT can grab your whole system to take it in to the shop so much easier. Plus they use less electricity so they can act like they are "going green."
Thanks for all of the replies. I have convinced IT Dept. to hold off on the Elitebook. I agree with the laptop vs. desktop issue and being able to get more bang for the buck with a desktop, however, I do need the ability to be mobile at any given time due to the nature of our business (gas and electric utility).
Jody
