Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
profile issues autocad 2009 and vista
2 REPLIES 2
449 Views, 2 Replies
autocad 2009 update 3 on vista 32 or vista 64
permissions set to local admin
TOOLS-OPTIONS-PROFILES-RENAME (of active profile) or ADD TO LIST freezes
autocad
IMPORT seems okay
When will AutoDESK address this issue, which was previously posted over two
months ago?
Jamie
2 REPLIES 2
TravisNave
You are unlikely to gather much support for a 2009 product when 2011 is the latest release. This will be especially true if the problem has been resolved in later versions. I would not hold your breath on such expections.
Autodesk Forums:
>>>...permissions set to local admin...<<<
So the problem does not exist if the log-in was a higher access level?
Dean Saadallah
http://LTisACAD.blogspot.com
Administrator Productivity
