i have converted plt files for KyoceraMita 4850, HPdesignjet 4000 HPGL2/RTL, and Canon iR c3220
PCL5c
The HP is definately HPGL2, but i think the Kyocera and Canin use a proprietary format.
They *do* all use hdi system drivers when plotting with autocad.
i could not convert the attached .plt file. What device was that plotted for ?
(email addy is bogus, do not use unless you want to spam the gov't agency that monitors spam)
Doug K
Windows XP Pro SP2
LandDesktop Companion 2008 SP2
HP Compaq dc7700p Convertible
Intel Dual Core 6400 @ 2.13GHz
4G Ram (3.5 usable), 232 GB HD
ATI Radeon X1600 256MB
Dual 19" Dell Monitors
Kensington Trackball (left-handed)
Logitech G15 Keyboard
"Dustin"
wrote in message news:5798417@discussion.autodesk.com...
I've tried that method with Adobe Distiller 8 pro and have the exact same
message as you. So Dougk, how do you make it work. What format is you PLT
files written in?
"A+P" wrote in message
news:5798263@discussion.autodesk.com...
I've tried your method running Adobe Acrobat 7.0.7 Distiller Professional
Version.
But no can do. This is the error log notice I receive:
%%[ Warning: Empty job. No PDF file produced. ] %%
You try the attached PLT which Viecompanion had no problems viewing and
converting to PDF.
Let me know what's the trick to get acrodist.exe to work.
Paul
"DougK" wrote in message
news:5797834@discussion.autodesk.com...
just drag the .plt file(s) into it or associate .plt with acrodist
exe and
dbl-click on the .plt
file.
there are some settings you can adjust (dpi, etc) if the default doesn't
suit you, but once it is
set , you are good to go.
that monitors spam)
Doug K
Windows XP Pro SP2
news:5797478@discussion.autodesk.com...
How can Acrobat Distiller convert a PLT to a PDF?
Paul
news:5797334@discussion.autodesk.com...
Acrobat distiller is what I use - fast and easy.
that monitors spam)
Doug K
Windows XP Pro SP2
Int
"larry" wrote in message
news:5797249@discussion.autodesk.com...
Does anyone know of a way to turn .plt into .pdf?
Larry
