It's been awhile since I last used AutoCad (like, 2000i).......Has AutoCad developed its own plot stamp for sheet drawings, or is there a block and lisp routine available to download?
Solved by dgbitts. Go to Solution.
I use both a PLOTSTAMP set up in the Plot command, and a MTEXT set of Fields.
One of the advantages of the plotstamp is for smaller detail areas in model space, it will tell you the scale it was plotted at.
The MTEXT fields are probablly overkil, but I rely on them for the most current drawing file information, not just the latest plot.
Reid
Thanks! That's a big help. It's been since 2000i that I have fiddled with autoCad at all. Trying to shake off the rust and get up to date again.
