All inkjets and laser printers are raster printers. The big difference
here is whether the computer performs the rasterization from AutoCAD
vector output, or whether the rasterization is performed in the printer.
When vector output such as HPGL is sent to a printer, then the printer
has to have sufficient memory and processing power to complete the
rasterization. AutoCAD traditionally has had the ability to generate
vector geometry when sending it to a pen plotter. Of course, no one
really has pen plotters anymore. In addition, if you're using and
AutoCAD-based product, it may have a combination of vector geometry and
rasterized images. If that's the case, then the output to the printer
(they are all printers today, even if they're called plotters), will be
a combination of output. That's why most modern plotters today have a
tremendous amount of both processing speed and memory.
I remember when the HP 600 plotter was introduced. If you sent an
AutoCAD file to the plotter, then it would sit there and process the
image (rasterize) for anywhere from 2 to 10 minutes or more, before it
would actually start printing. HP 750 improve done that in that it
started rasterizing the input, and simultaneously started printing aas
it rasterized.
Everything changed when Autodesk and other tech companies went to a true
Windows based application. Only AutoCAD is a hybrid. All other
applications primarily utilize Windows system printer drivers which send
for the most part rasterized output to the printer, reducing processing
time on the printer side.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr. Tel. (260) 399-6615
http://teknigroup.com
