I want to use a previous version of Plant Design Suite Premium Desktop Subscription 3 months. When logging into my Autodesk Account I see two serial numbers one for 2015 and one for 2014. Of Course there are different product keys. Is it possible to activate the version 2014 using a data medium and activate it with the serial numbers and product key or do I have to download the suite version 2014 in my account to be able to activate the 2014 version.
Solved by camilo.lemos. Go to Solution.
Hi @SusanneNell
You can activate Plant Design Suite downloaded/installed from any sources using the serial number and product key from the Autodesk Account. You don't need to specifically download it from Autodesk Account to be able to activate it with the Autodesk Account serial number and product key.
Please accept as solution if my post fully answers your question.
