hI,
any one help me to sort out this issue.
Autocad drawing file has LINKED WITH EXCEL FILE.
While publishing the DWG file into PDF using the Autocad LT2009, PDF print quality is Good and readable.
And publishing the same drawing using Autocad LT2010, the quality of PDF is not readable.
Recently we have upgraded Autocad LT2009 to LT2010.
What could be the reason. Please anyone can sort out this issue.
We use DWG to PDF.pc3 or PDF995 converter plotter file for converting PDF.
thanks
satya
Did you make the mistake of "migrating" to R2010 from R2009? Repair reinstall R2010, then follow the other suggestion below.
Did you change the PDF output settings at all in R2010? factory settings are quite low: PLOTTERMANAGER command>open DWG TO PDF.PC3 file>device/document settings>Custom Properties>experiment with Raster resolution.
Hope that helps.
