Dear All,
I'm trying to open the DXF file in autocad by using DXFIN command and also using inserting as a block, nothing works not only that but i'm getting the message given below. Can somebody please help me.
Error in BLOCK_RECORD Table
Invalid symbol table record name: " FA 0 0137 3 A_02965" on line 31202.
Invalid or incomplete DXF input -- drawing discarded.
Rijnas
Solved by dkoppenol. Go to Solution.
Hello Rijnas, i had the same with several old dxf files. Autocad donn't help you with this kind of problems. Try AutoDWG Converter 2013.
www.autodwg.com. It is not freeware but you can test a single file. Perhaps it is for you a solution.
Best regards
Dolf
