Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
open using minimal resources
8 REPLIES 8
Message 1 of 9
tedwardspg
964 Views, 8 Replies
Is there anyone that might be able to help me on this one?
I have users that are using AutoCAD on laptops. I would like to know if there is a way to open AutoCAD using ablolute minimal resources. After the program is opened then we might be able to lioad the addition resources needed. They do need to pull a license off of VPN. I would like the user to only load the nessesary item to start up the program.
ACA 2013
Windows 7 enterprise
Intel core i7 860 @ 2.80GHz
16GB RAM
NVIDIA Quadro FX 1800 - 4GB
8 REPLIES 8
Message 2 of 9
pendean
in reply to: tedwardspg
Not really, AutoCAD is a resource hog of an app.
Your AutoCAD version? Your PC specs? What is the problem now that you are wishing to avoid with this idea?
Message 3 of 9
tedwardspg
in reply to: pendean
Sometimes AutoCAD takes 5-6 minutes to startup sometimes more. Hoping to avoid this. I already have done the /nologo thing in the Target properties oof the icon.
ACA 2013
windows 7 enterprise
intel core i7 860 @ 2.80GHz
16GB RAM
ACA 2013
16GB RAM
Message 4 of 9
pendean
As a test... unplug from the network/internet/turn off wifi: does the slow start problem go away?
Are there any third part add-ons installed? remove them.
Is everyone logging into Autodesk360? If they are not using it does uninstalling it help?
Message 5 of 9
tedwardspg
Can't unplug. Network licence.
ACA 2013
16GB RAM
Message 6 of 9
tedwardspg
I uninstalled the Autodesk 360 from my station and startup time dropped from 47 seconds to 36 seconds. This might be really helpful when trying to work with your average laptop.
ACA 2013
16GB RAM
Message 7 of 9
pendean
Netowrk licensing over wifi? or wired? Connection speed? Server OS?
Message 8 of 9
tedwardspg
they have it so the laptops are connected via VPN and workstations are hardwired. we are using broadband. Server is Windows server 2012 I believe.
ACA 2013
16GB RAM
Message 9 of 9
jggerth1
Users can check out a license, and then run unconnected wiht networking disabled.
But -- without adeqaute horsepower on the laptop, it won't be speedy no matter what you try.  Sorta like moving cross country in a VW Microsbus, vs a semi with a 53' trailer.  It's possible, but.....
Administrator Productivity
