What is the reasoning behind creating this network configuration?
In a typical DHCP setup, you would set aside a range of IP addresses (or a set
of static IPs) in the DHCP server that DHCP does not attempt to lease out. These
physical boxes can be anywhere on the network.
Also, I question why you are using the server as a gateway in this manner. It's
probably more beneficial to have all PCs, whether statically or dynamically
addressed, connected to the central switch - including the router.
If you did this because your hub ran out of ports, and are using the ports on
the router, just go out and buy a larger switch and streamline the entire
network wiring.
Matt
mstachoni@home.com
mstachoni@beyerdesign.com
On Wed, 20 Mar 2002 13:55:16 -0800, "Nick@Palmer & Lauder"
wrote:
>If I have 2 seperate networks - one on static ips, one on dhcp ips.
>connected through a double addressed server. Is it possible for the static
>folks to look through the server to see the dynamic folks? the server has 2
>ethernet cards. one has a static internet address connected to a router with
>4 other machines also having static inet ips. the other ethernet card is
>connected to a hub serving a bunch of pc's dynamic ips. Server is using
>win2k server.
>Thanks
>Nick Harper
>CAD Manager
>Palmer & Lauder Engineers, Inc.
