Hello I'm using student version of Autodesk Sketchbook Designer but it keeps crashing and today I cannot open a saved file. This file is very important to me so please help. I have tried open it with Autocad, DWG trueview and inventor but no luck. The file has been attached if anyone want to have a look at.
Kawin
Please help
Welcome to Autodesk Forums!
885 KB is pretty small for a DWG file.
Search your computer to see is there is an idk2.bak file.
Your file opened here but there is nothing in it.
No Blocks, Layer 0, only the expected Text and Dim Styles.
QSELECT returned that there are no objects in the current drawing.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Is DWG the native file format for Sketchbook Designer?
You say "tried open it with Autocad, DWG trueview and inventor but no luck."
What does that mean, that the .DWG file will not open (crashes) or there is nothing in it?
Your attached drawing opens fine here, and DBLIST reveals there are no entites in it, and not much more. It looks like a standard empty template drawing.
