Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
NCS Discipline Designator
1 REPLY 1
sturner7277
813 Views, 1 Reply
ok, i have spent the past several weeks working on templates and charts for movign our offices to use the NCS v4.0. while doing some prelim. show and tell, a question on the discipline designator came up on why i was using two letters and not just one. my response was using VF = Survey Field, CG = Civil Grading, CS = Civil Site helps the layer name be descriptive and sort better in a list.
so to shorten this up my boss wants to know what to other firms use? a single or double discipline designator.
thanks!
-Sean
Just a CAD Manager for a Civil Engineering firm...
1 REPLY 1
jggerth
in reply to: sturner7277
A single discipline code has been sufficient here -- mostly a mix of civil and survey work
generally different 'types' under the same discipline are in separate drawing files xref'ed as needed.
Administrator Productivity
