I just included the ctb for the NDS. We actually use a modified
version. We do not use the printable colors. All of the colors print
black (except 250-255). Our xx7 plots at 0.002 which is different from
NDS. Also colors 8, 9 we have as 0.002 and 0.014. As a left over from
another office that I worked at we have pen 101 mapped to 0 screen to
provide a no plot color. As we have our lines set to merge we can't use
it as a wipeout, but there are times that you want information located
on the drawing that you don't want plotted but you do want associated
with particular layers (ie freeze and thaw with those layers).
Anyway the result is that we thought that the NDS was a place to start
and modified it as we needed.
Mike
Glenn White wrote:
> replied to you in customer files with another similar ctb - addresses the
> 250's (greys) a bit differently.
> being a long time user (my first AutoCAD ran with an amber screen), I am not
> as enthralled with multiple colors as some folks - I am a layer freak though
> (everything in its place and a place for everything, just don't go overboard
> with every itty-bitty piece of something).
> "Mike Sapp" wrote in message
> news:3C9FAAC8.3010805@integrarearch.com...
>>We also have adopted a modified version of the NDS color/line weight.
>>One of the issues that I see constantly being brought up is trying to
>>make the line weights match the colors on screen, the brightest on
>>screen being the heaviest line weight. The problem with this concept is
>>that each person sees colors differently. Some are colorblind. I have
>>worked in several offices, some which use color brightness as the guide
>>and some that use placement on the acad diagram as the guide, and I have
>>found that the easiest to use is the ones that don't use the brightness.
>> As in the NDS red is the thinnest at 0.007. This is the first color
>>on the ACAD color dialog box. The line weights get thicker as you move
>>along down to white being the thickest. Left is thin, right is thick.
>>You have a relative position to use.
>>The other thing that the NDS allows is the designation of color for
>>types of objects. The color sequence from 90-99 could be for doors,
>>with a full line weight range. The color sequence from 130-139 could
>>be for glazing with a full line weight range. The sequence from 190-199
>>could be for walls. etc. etc.
>>This is actually quite an intuitive system. The higher the last digit,
>>the heavier the line.
>>We too have added a thinner line weight as well. We changed the xx7
>>colors to be 0.002 for those times we want really thin.
>>I have placed a file in the CF (Subject: NDS pen map) that has a dwg the
>>shows the colors and plots the thickness. There is a ctb file NDS.ctb
>>that is associated. There is also a layout on the drawing that plots
>>the AIA layers that come with Architectural Desktop.
>>Sorry for the lecture.
>>Mike Sapp
>>Integrare Architecture
>>Eugene OR, 97401
>>jmodglin wrote:
>>>I work for a Civil Engineering firm and we just recently implemented a
>>>new 'Pen Map' based on NCS. We did not have enough "Halftones" so we
>>>edited 8, 9 to be halftones and we tweaked the sizes but all in all it
>>>works great! Joshua Modglin
