snip>>> 18. What is the command-line sequence you would use to change all
>> Xref layer colors to color #8 (gray)?
>again, many new Users will not be frequenting the command line.
>Layer Filters, in Layer Manager is probably the most used method...
Yep, but I'm also interested in speed, which means to me a profound
understanding of the command line. I don't think you can know AutoCAD
without
understanding command line syntax.
'-la c 8 *|* "" ' is imminently faster than opening any dialog box -
particularly the layer dialog.
Now that I "see" it, it makes perfect sense.
But it was just hovering on the edge of my "dirt-dauber" mind until now. ;0)
I started reading this thread at roughly 4:55 PM MST here in AZ.
Most often we wouldn't be changing all Layers colors in a particular XREF in
this manner. Sometimes we want a certain Layer to be less "Screened" than
the others in that XREF. Some need to stand out more than others.
At least in my mind. ;0)
Don Reichle
"The only thing worse than training your staff, and having them leave is -
not training your staff, and having them stay." 😮
A reminder taken from Graphics Solution Providers' Calendar page
!! Please discuss whatever we tell you with your SysMgr !!
!! They appreciate staying in the loop 🙂 !!
LDT-2K4
AMD Athlon64 2.2GHz 2GB RAM
XPPro 32bit SP2
WD Raptor 10K-rpm 37GB HD
Nvidia GeForce FX 5200 128MB
"The only Constant is Change".
"Matt Stachoni" wrote in message
news:5569636@discussion.autodesk.com...
On Mon, 30 Apr 2007 18:49:11 +0000, Corey A. Layton wrote:
>> 7. What is a fast method for selecting MText objects with a Style of
>> "MEDIUM"?
>A good gauge to se if the User uses "Quick Select".
Which she answered correctly.
>> 8. What does the FROM osnap do?
>nice question.
>although, osnap tracking is a less archaic way to accomplish the same
>thing...
Well, perhaps for some people. I think Osnap Tracking completely sucks,
myself.
But it was weird enough that I figured it would throw someone, and I was
right.
>> 10. What are the special rules concerning layers and colors in Blocks?
>This answer could be an AU topic .
She actually did give the right answer I was looking form, which was to use
Layer 0 and color Bylayer.
>> 11. If you dimension two parallel walls and get a dimension of 14'-5
>> 13/256", what do you do?
>Label yourself a "deconstructionist", and cop an attitude?
Perhaps.
>> 12. What is one way of dimensioning something along an angle?
>good question.
>I assume Dim Aligned, and rotate UCS are acceptable answers?
I was really looking for UCS. I think Dim Aligned dimensions are next to
useless
because of how they behave, and wanted to see if she knew that.
>> 14. What does PSLTSCALE do?
>good question.
>people should know this.
She had no clue - never saw it before.
>> 16. What is an easy way to close a Polyline?
>good question
Properties 🙂
or Pedit Close.
It's important because so much depends on closed polylines, and I had a rash
of
incidents last week where hatching failed because people weren't clocing
their
plines.
>> 17. What support file do you modify to create custom command aliases?
>not average USER fodder, IMO.
Again, wanted to see what she knew. If she did, great, if not, no biggie.
without
>> 20. What command do you use to change your default Plotter?
>OPTIONS...
Yip
Matt
mstachoni@comcast.net
mstachoni@bhhtait.com
