Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
bthatcher
159 Views, 2 Replies
Multiple Profiles
I have a need to create a separate profile for a user who has a laptop, basically on and off the network. It seems the easiest way would be to give them 2 desktop icons referencing different profiles. But there is an intimating string of text in the 'target' property of the icon. Does anyone have a reference or example, I would like a better understanding before I get into it.
Also, any suggestions on keeping duplicate support files up to date. Thanks.
2 REPLIES 2
in reply to: bthatcher
After the target, place /p ***** where **** is your profile name. That will
cause the switch at startup. LDT users are quite use to this trick for
dealing with Map vs. LDT.
And I used offline folders with quite a bit of success in just this
scenario.
HTH
James Wedding, P.E.
Engineered Efficiency, Inc.
Civil 3D 2006 SP2
XP Tablet, SP2, 2GHz, 1.5G
www.eng-eff.com
www.civil3d.com
bthatcher <> wrote in news:5088118@discussion.autodesk.com:
> better understanding before I get into it. Also, any suggestions on
Or you can replicate your netork drives:
subst j: c:\j
subst i: c:\i
Cteate a .bat and modify the above and run before starting cad.
Administrator Productivity
