Can't sleep - huh, Clinton?
Same question could be applied personally though - I suppose. 🙂
Don Reichle
"The only thing worse
than training your staff,
and having them leave is -
not training your staff,
and having them stay."
Courtesy Graphics Solution Providers
LDT-2K4
AMD Athlon 64 3200+ 2.2GHz
XPPro 32bit SP2
1GB RAM
Nvidia GeForce FX 5200 128MB
WD 36GB Raptor
"clintonG" wrote in message
news:5136663@discussion.autodesk.com...
Doing this daily is asking for errors and ommissions.
Somebody should write a .NET application to automate the validation of the
business rules which are applied to repathing the resources.
<%= Clinton Gallagher
NET csgallagher AT metromilwaukee.com
URL http://clintongallagher.metromilwaukee.com/
"Don Reichle" wrote in message
news:5136587@discussion.autodesk.com...
Hey Brian;
The only caveat to this may be to proclaim...
"Thou shalt not in any way change the names of the Folders! Ever!"
That's the only issue I've seen Relative Pathing fail in.
It's not much fun to have to go back and set them over again. Plus the time
that it takes if you're a ways along in "plotable sheets" dwg creation.
Though the use of Multiple Layouts would have you "one-up" down that
particular road.
Maybe I just need to learn a little more though.
Don Reichle
LDT-2K4
XPPro 32bit SP2
1GB RAM
WD 36GB Raptor
wrote in message news:5136495@discussion.autodesk.com...
Relative pathing for all x-ref's. Make sure your directory structure is
consistent between firms. Relative pathing will allow you to ignore drive
mapping/server naming/UNC conflicts.
Brian Beck
CAD Manager
Rainforth Grau Architects
