Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
144 Views, 2 Replies
Menuload
Trying to load a partial menu (pulldown selection)
into my current menu.  I do menuload, go to the server where the file
(*.mns) is stored and load it.  Then I go to that menu group on
the menubar and add the selection I want to my pulldown.  It works
fine.  As soon as I close and reopen A2Ki, the pulldown is gone and I must
reload it all again.  I was hoping to be able to load pulldowns (this is a
block selection menu) on all my users computers without having to continually
copy the file to their pcs.  This way I could make changes once and
when they start cad it would reflect the changes.  Any suggestions?
Thanks.
Jeff Crawford
Project/CAD
Manager
W.H. Porter, Inc. / Poligon Park Architecture
Holland,
Michigan
e-mail:
href="mailto:Jeff@poligon.com">Jeff@poligon.com
AUGI
#15985
2 REPLIES 2
Are you setting a current profile at launch time,
and does this match the profile that you are menuloading the server menu
into?
Also if you are using LDD (maybe other vertical
apps also), you need to save the menu palette after the menu is loaded (under
projects).
Bruce
style="BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
selection) into my current menu.  I do menuload, go to the server where
the file (*.mns) is stored and load it.  Then I go to that menu
group on the menubar and add the selection I want to my pulldown.
It works fine.  As soon as I close and reopen A2Ki, the pulldown is gone
and I must reload it all again.  I was hoping to be able to load
pulldowns (this is a block selection menu) on all my users computers without
having to continually copy the file to their pcs.  This way I could
make changes once and when they start cad it would reflect the changes.
Any suggestions?  Thanks.
Jeff Crawford
Project/CAD
Manager
Holland,
Michigan
e-mail:
AUGI
#15985
dmhamr
Jeff,
In our case, we have inserted the following lines into a startup routine.
Where "menuname" = your custom menu
(command "menuunload" "menuname")
(command "menuload" menuname")
(menucmd "P17=+menuname.POP17")
David Hammer
Applications Administrator.
Cimarron Engineering Ltd.
Calgary, Alberta.
Administrator Productivity
