With Windows 2000 I've started using the "Work Offline" folder option.
What you do is choose a folder (fww never tried a whole drive before),
right-click, and pick work offline. Now, when you disconnect you still
have that folder available locally with the drive mapping intact, if any.
When you reconnect it syncs. If anything has changed on the server you'll
get the new stuff and vice-versa. If an item has changed both places
you'll get a notice and can manually resolve the differences.
Other than that, you could use a batch or WSH file to detect when it's
connected to the network and have it re-copy everything to the local. (if
exist "L:\xxx" then copy ...) However, if it's a lot of bytes it may be
too time consuming. I don't know if you can specify something like "if
date is newer than 10 days of today then copy", but you probably can.
Enjoy,
Stef
mailto: yodersj@earthlink.net || Drafter, Leather-worker
http://home.earthlink.net/~yodersj/ || Dos, Win, LT
http://www.geocities.com/yodersj/ || Computer How-To
"Giebeler" wrote in
news:B70708947EE6A30BF290B1DDDFE22351@in.WebX.maYIadrTaRb:
> PERFECT! Thank you - it works great. BTW is anyone using a program or
> command that could synchronize the laptop's mapped folder with the
> "real" folder on the network when the laptop user connects to the
> network. This way every time they connected the laptop would be
> updated with the current standards, notes, support files, etc.
> Jonathon
