You only loaded the lisp file. you never ran the command. after the file
was loaded the command should show. hit OK to all the dialog boxes and then
type "lockup" at the command prompt. Lockup is the command name.
Jonathan Ho wrote in message
<1B4ACDFD92E25385108E4822E53A2D10@in.WebX.maYIadrTaRb>...
>Sorry but I don't know if I did it right. I open a file and appload the
lisp
>file that you sent me. Some dialog box pop up with warnings and all I did
>was click OK. The loading of the lisp file was successfully loaded, but
>nothing really happen. I could still modify the drawing and save it.
Thank
>you anyways.
>"AWeissner"
wrote in message
>news:E65FDA01D0EAC99C1BF02D31E6259FB9@in.WebX.maYIadrTaRb...
>> That file I sent you did not do what you want.
>> <6A29E55F13C84191E6F4A56CA1E548CC@in.WebX.maYIadrTaRb>...
>> >You are exactly right Mark. Does anyone have a solution to this
problem?
>> >"Mark Scacco" wrote in message
>> >news:097807F23A07AF48581F02CE692EF647@in.WebX.maYIadrTaRb...
>> >> How about using the new Digital Signature Extension to "sign" the
>> >drawings.
>> >> This way, you'll know if its been modified or manipulated.
>> >> However, it really sounds like your client wants access to your
>linework
>> >for
>> >> other uses besides panning, zooming, etc. and your company does not
>want
>> >to
>> >> grant this access. If this is indeed true, then a digital signature
>will
>> >> not provide the desired protection.
>> >> Mark Scacco
>> >> Scacco Consulting, Inc.
>> >> "Jonathan Ho" wrote in message
>> >> news:164B944E5622AE8CEF75AFEC3A8DB2E2@in.WebX.maYIadrTaRb...
>> >> > Is there a way to protect or lock a drawing file so that the files
>can
>> >not
>> >> > be change? The only thing that I want my customers to do is opening
>> the
>> >> > drawing files, zoom in and out, pan around and plot. Does anybody
>know
>> >of
>> >> > such a program that I can buy or download? I've tried CADlock, but
>> this
>> >> is
>> >> > not what I was really looking for. CADlock would do everything that
>I
>> >was
>> >> > looking for but the only problem is that it would change the
>extension
>> >to
>> >> > dwx. You can not open a CADlock file without having to download or
>> >> > installing the program. My clients would like to open it with
>AutoCAD
>> >and
>> >> > not having to install a separate application. Your suggestions are
>> >> greatly
>> >> > appreciated.
>> >> > Thanks in advance,
>> >> > Jonathan
