I am looking for a routine to close appload as soon as it is opened. Any ideas?
Solved by tedwardspg. Go to Solution.
The Undefine command works pretty well... Undefine Appload...
If your guys know about redefine, you might have to Undefine Redefine...
BE CAREFUL though... Do some googling about undefining autocad commands first...
I just need a routine that will allow appload to open when Acad is started but will imedietly close it as soon as it opens. For some reason the CAD does dot fatal error when appload is initiated on start up.
I learned that this cannot be done
