The problem with having a generic legend that is placed on a seperate plan
sheet is that it does not allow for situations where lineweights and
linetypes vary according to the particular layout. For example, a plan sheet
that is intended to show proposed road grading would also show the proposed
utilites but the lineweights and linetypes would emphasize the road design
elements. The sewer and water sheets would be opposite. My intent is to have
a legend on each layout as needed to emphasize the pertinent design
elements. Plan and profile layouts for the road grading would be in one
drawing, while the plan and profile layouts for the utilites would be in
their own drawings and so on, with each set of layouts having their own
pertinent lineweights, linetypes and legends. All layouts would use an Xref
to the Master Design drawing, but the layer definitions would be adjusted to
suit the purpose of the layouts.
Perhaps this approach to sheet layouts is too complex to be worthwile, but
if an approach could be devised that was not difficult to manage it would
make plan sets very clear.
"Neil W" wrote in message
news:4888460@discussion.autodesk.com...
So far it looks like most of you are using predefined legends and editing
the drawings to fit, or editing the legend to comply with the drawing. I was
hoping someone had figured out a way to make legends more dynamic, but
without programming it looks like there are no easy ways around this
problem. I am new to this company and there are NO standards in effect, so
until we/I can implement the standards, Legends are a major time waster!
Thank you all for your feedback.
news:4886325@discussion.autodesk.com...
I am wanting to know how CAD mangagers are applying drawing legends to
xrefs. I am currently creating a legend in the source drawings and then
using a viewport in the master drawing layouts to show the legend, so that
the legend reflects any changes to the xref layer definitions in the master
drawing. The problem arises when layers in the XREF are toggled off in the
master drawing. This leaves "blanks" in the XREF legend. Also, there are
problems when the linetype in the legend of the source drawing does not
display properly due to linetype scaling.
The application is Civil Design, with a minimum of a Base (Topo) drawing,
Design drawing, and Plat drawing xref'd into the plan sheets. Each drawing
has it's own legend.
