Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
Lack of a common software architecture
4 REPLIES 4
jcstahl
379 Views, 4 Replies
Most of our firm's work is related to municipal wastewater treatment plant design. We offer the full design package: Civil, Architectural, Structural, Process Mechanical, HVAC, Plumbing and Electrical design. We would like to create a set of drawings that can be managed in a way that can be plotted, filed and accessed in a logical manner. Due to the way each software (Plant 3D, MEP, Architecture & Civil 3D) manages their files, this has become a nightmare for file management, plotting and file access.
I do not mean to rant and rave, but this is a real problem. Autodesk has too many products and it seems that there is no communication between each software group. To me there should be a common software architecture as a base for all Autodesk software products. This base architecture should help make the different software packages look similar, create the same file structure, have compatible AEC objects, create views in a similar fashion, etc... Take a page from Apple/Mac and reduce the number of products offered, bundle the software for firms that do multiple disciplines of work and sell more software. Any comment from anyone?
4 REPLIES 4
in reply to: jcstahl
Yup. Which is why I love the Revit platform.
Matt
matt@stachoni.com
dgorsman
To a certain extent they do cooperate, but there is a limit imposed by what each package does. Architectural work is very different than piping, is very different from subdivision layout. If they were all based around the same core concept (at a deeper level than current) there could be problems adding new features which could break something needed by another offshoot. Give it another couple of generations and things will be working a little closer.
And find something different than Plant3D - IMHO its still at least one version away from being useable in a production environment.
omc-usnr
Your joshing, right?
Autodesk wouldn't be able to sell four different packages to one firm if they did what you want.
Reid
jcstahl
No, I wouldn't be joshing Reid. The four products I would like to at least work together would be Plant 3D, MEP, Architecture & Civil 3D as mentioned before. Yea, make it a suite that works together within Project Navigator, so you can keep track of the entire project in one location. Maybe that’s why they call it a “project” and not “part of a project”. What a concept!
Administrator Productivity
