Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
Message 1 of 15
1455 Views, 14 Replies
James Wedding, PE
I just received "Mastering Autocad Civil 3D 2008.
Does it have to be so thick?
It looks very interesting. I'll let you know how I do with each chapter?
Do you have a "cliff note" version? (kidding)
wow, 1st sentence under Acknowledgements, grammar mistake. (buzzer sound
#1)
Sorry, couldn't resist.
14 REPLIES 14
Message 2 of 15
You're welcome to send feedback and comments to Mastering@ the first
domain below as you find problems.
Which sentence?
James Wedding, P.E.
Engineered Efficiency, Inc.
The Site: www.eng-eff.com
The Blog: www.civil3d.com
The Book: www.masteringcivil3d.com
C3D SP2 Mac Book Pro, XP SP2, 3GB
Message 3 of 15
1st sentence under acknowledgements.
"This book is a team effort, with more authors than on are the front cover."
I'm not the most grammar correct person either.
wrote in message news:5904413@discussion.autodesk.com...
Which sentence?
James Wedding, P.E.
Message 4 of 15
Wow. All those editors and reviews for naught.
James Wedding, P.E.
Message 5 of 15
I missed that one also.
funny. 🙂
Message 6 of 15
Well, maybe they are Amish, and this is their quilt. 🙂
Joshua Tapp
wrote in message news:5904738@discussion.autodesk.com...
James Wedding, P.E.
Message 7 of 15
Y'know, I had to read it about six times before I saw it...
Kate Morrical
AutoCAD LT Technical Marketing Manager
James Wedding, P.E.
Message 8 of 15
Me too.
I read it and my eyes and thoughts were all screwy.
I'll let you all know how good sentence (2) is tomorrow.
I just need T.I.M.E. to start this.
"Kate M" wrote in message
news:5905120@discussion.autodesk.com...
Kate Morrical
James Wedding, P.E.
Message 9 of 15
Careful, Owen is listening.
Joshua Tapp
|>Joshua Tapp
James Maeding
Civil Engineer and Programmer
jmaeding - at - hunsaker - dotcom
Message 10 of 15
Blame it on Jickey.
James Wedding, P.E.
Message 11 of 15
Owen Wengerd
President, ManuSoft <>
VP Americas, CADLock, Inc. <>
Message 12 of 15
James-
I have 12 years of civil microstation experience.  -  and some basic autocad.
How long takes to learn  civil3d  and be productive,  pass the certification exams...
Are you familiar with Rick Ellis,  dvd course on cd3 ?
Message 13 of 15
JamesMaeding
learning time on c3d depends on if you understand other civil progs. If just "mapping" skills from one to the other, less time.
The wonderful thing about C3D is that the more you know it, the more workarounds you must invent.
I'm still wondering how to deal with data reference objects that I need for design, in a base file, but do not want them xreffed to the sheets. You can make no-show, or freeze, but they still cause the "synchronizing references" activity in the sheets whish majorly slows things down. I currently just dref surfaces, do things with them using tools we wrote, then detach.
How in the world do people work that must keep the surfaces attached to bases?
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
Message 14 of 15
in reply to: JamesMaeding
you keep 1 "base" drawing that is 2d, and has no references in it.  Then x-ref that drawing into others to create your surfaces, profiles etc.  The "plot drawings" pretty much just have the 2d base plus the data shortcuts required for each.
Almost need a flow chart so you don't end up with circular references.
This really sounds more confusing than it is.
Message 15 of 15
JamesMaeding
well, the root problem is the idea of sharing data via an object in a drawing.
Those objects are heavy, and load on open, not just when you need them.
Almost any other system would work better, Autodesk should have loked at this closer in the beginning, but was so caught up in the idea of dynamic objects, that sharing issues were left unattended. Now we have this conflict.
The answer is to make data external, and available, but not accessed til needed.
So maybe share data via some different type of attachment, not xref, and not dref.
Then allow users to make objects from data if desired.
Most of the time, data is invisible though (labeling of elevations in plan, profiles are not present for grading plans).
Administrator Productivity
