Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
Inventor 2012 crashes in Windows 8 Release Preview Build 8400
3 REPLIES 3
shyamplastic
894 Views, 3 Replies
I just upgraded to Windows 8 Release Preview Build 8400. I am facing problem of Inventor crashing frequently. Does any one have come across such situation, and does any one have a solution to this.
Thanks in advance,
Samir
3 REPLIES 3
subpartner
in reply to: shyamplastic
go back to a supported operating system
TravisNave
Windows 8 is still a beta product and is not supported for use in actual production environments.  Your Autodesk product is not supported on this.
That being said, in most cases, Inventor crashes are due to video card drivers. So, you might consider using a WHQL certified video driver for Windows 7, if you can find one that works.
Autodesk Forums:
DarrenP
in reply to: TravisNave
or use one certified for windows 8
both nvidia and amd have released beta drivers for windows 8
DarrenP
Administrator Productivity
