See my comments below:
wrote in message news:4879592@discussion.autodesk.com...
Maria,
Several considerations we gave when choosing to go the BIM route were as
follows:
1. Why did we want to use BIM and what results did we hope to achieve with
its use?
The book I mentioned covers this in detail. It asks the questions "What is
your firm size, what type of projects, what is you firm culture, what kind
of personnel, how is your technology in the office, etc....
2. Will the platform we choose to utilize be accepted / understood by those
we work with (subs., customers, etc.)? I.E. can they quickly and
efficiently work with out output?
In the case of Revit, the answers to all of these is yes. Revit reads and
writes DWG. you can continue to work with all of your consultants etc as
you currently do. Beyond that, new Revit products are being introduced, as
Revit Structure was just released, and Revit Systems (MEP) is due out in a
year or so. On the horizon is yet another Revit product. Additionally,
your clients/consultants/contractors will get additional value from a Revit
model, from using the BIM model for Facilities Management after the project
is complete, to having a virutal model for your consultants to run
structural and energy analysis on, to a complete model to get exact quantity
takes offs for estimating, and a model that can be phased to show
construction phasing. Will your software be able to provide these things,
or will it be just another add-on to an existing product that requires
constant management and attention to assure it works correctly?
3. Were we willing to dedicate ourselves to new training and new hardware?
Any firm should already have plans for future training and hardware. In the
case of hardware, all firms MUST have a plan in place to keep up with the
rapidly changing computer technology. Only 10 years ago, a 200Mhz processor
was "fast", five years ago we were getting "top of the line" 750mHz
machines, and today, 3Ghz machines are the norm. Whether its AutoCAD or
Revit, or something else, computers with horsepower are part of the business
to keep our information/graphically intense projects running smoothly. If
you make a software change, and find your computers aren't fast enough, well
it was probably time to make a change any way. Training - always have a
training plan in place for your firm, whether its to train on new software,
or to keep your people fresh on an exisitng one. Even AutoCAD is on a
yearly release cycle now, so plan on training in your yearly budget.
4. Did we have access to a large trained user base on the platform of
choice (esp. in regard to new employees)?
As you transition towards Revit, your AutoCAD trained staff can continue to
work in DWG. As more get trained, you will rely less on DWG. If it were
the case to train those on either Revit or ADT, you will get much more value
from Revit training, as those trained will actually use most of what they
learn. You will here it time and time again: most trained on ADT never use
the full toolset they have learned, as it is too complicated. Most use only
the basics.
