Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
Message 1 of 133
sbsaint
16825 Views, 132 Replies
I hate Revit
Ive been required to learn Revit, Ive been at it for 6 months now, I started on a trial version of 2009 then my company purchased 2010 and they changed so much in the two releases that I had to learn where everything was all over again, many for the worst. I find myself using other programs to model components in order to avoid the labourious and impractical procedures in Revit.
Using Revit to draft and model is like driving a car using a boatload of of push buttons rather than a steering wheel.
Ive been using 3D programs since 1995, starting with FormZ and have been using AutoCad since 2000. I think that Revit is a terrible modeler and a mediocre drafting tool. I admit that it does alot, but I have to jump through the hoops and mindset of a team of programmers who think this is the practical approach of what creating architecture should be, If this is a program that screams design, then Id rather go back to a leadholder and a Mayline. The program is NOT intuitive, and instead of me VISUALLY creating a building component with numerical parameters, Revit seems to operate in the reverse manner. Im constantly battling the Revit Gustapo dialog box that says something to the effect that my model is an illegal operation. Ever try to do a 2 path sweep? FormZ had this nailed 15 years ago, and I could easily draw any profile and the computer would do the calculations for me. Revit seems to make you work harder and not the other way around.
The interface sucks, edit parameter controls buried deep within two to three dialogue boxes. The steering wheel is a joke. Why would you make a virtual controller to replace something that your mouse already does? Its like going back to the time before they invented the joystick, and Im using the keyboard to play pac-man.
My bottom line, Revit is a chore to use, It doesnt think for you, it makes you do all the thinking. Its not fun to use at all, and it takes the wind out of your sails when trying to come up with concept designs, and has me scrambling to find a pencil. Edited by: sbsaint on Mar 24, 2010 10:53 PM
Tags (1)
132 REPLIES 132
Message 2 of 133
in reply to: sbsaint
You have to compare apples to apples. You can't compare AutoCAD, FormZ or
any other 3d modeling program with Revit since they're not BIM.
The question really is:
Are there any other BIM applications out there that are easier to use than
Revit, ie: Bentley Architecture or ArchiCAD or VectorWorks?
http://www.cad-addict.com/2010/03/list-of-bim-software-providers.html
Paul
wrote in message news:6360394@discussion.autodesk.com...
way around.
Message 3 of 133
sbsaint
Point taken, but it sounds like you are saying that BIM is supposed to be overcomplicated and laborious? If BIM requires me to think like a sweets catalog, then Id rather use Autocad and go back to the way I was doing all this before. My whole arguement about Revit is how it hasnt made my life any easier, in fact its made my job less enjoyable. Autodesk's lack of ergonomics of its UI, and the methodology for commands that have already been laid out before in other 2D/3D programs prior to Revit. This product has made it dreadful for me to come into work and to practice architecture for my current firm.
I absolutely hate the steering wheel tool. and the method for navigating in 3D mode. I can compare it to playing a race car game and using my mouse to control an on screen virtual steering wheel in order to drive the car, when I should really just be using the mouse. how clumbsy is that? The fact that Revit makes me edit almost everything from a 2D projection view doesnt make any sense to me at all. Its like a 2.5D program. When you launch the program youre by default starring at a 2D view, which really makes me feel like im not in an advanced state of design, nor a peice of software that is on the cutting edge of it. The software does alot of stuff, dont get me wrong, but it really feels like theyve taken the existing 2D cad programs and attached all these commands and features and tools and called it BIM, There are so many tools in Revit that just do one thing, i.e. "wall sweep" when other programs have one tool that does so many things, and these can be defined by the users imagination and not by the imagination of the programmers and developers.
I have two words that describe my frustration over Revit.... Sketch Up. Its only a matter of time before someone writes a library of ruby scripts that will do everything Revit does poorly. And wont cost an arm and a leg to purchase.
Message 4 of 133
the interface sucks
the family editing/creation is obtuse and scrolly
it takes 50 steps to accomplish one thing.
TDP
First things first, but not necessarily in that order.
The Doctor
way around.
Message 5 of 133
Alfredo_Medina
I love Revit. As any other program, it has some issues that can be improved as time passes by, but I find myself not having used my AutoCAD in a long time, ever since I understood how to use Revit. I keep my copy of AutoCAD Architecture in my computer just because I like the Detail Component Manager. But the more I use and learn and understand BIM and Revit, the less I use AutoCAD, believe me; and I was an expert user, even an instructor of AutoCAD and Architectural Desktop for many years. Now Revit is my choice of tool for architectural work. No doubt about it.
Alfredo Medina
info@planta1.com
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
Message 6 of 133
"A+P" wrote
> they're not BIM
But then, what is?
Message 7 of 133
sbsaint
Ive used many many programs for both drafting and modeling, and after using so many you begin to see similarities of what works best for intuitive UI and workflow. It seems like Autodesk didnt pay attention to any of that when they made Revit.
The steering wheel is crap, they shouldve made it look like a computer mouse so that I could use my mouse to control the virtual mouse making it more rendundant than it already is, whatever team came up with that aspect of the program failed miserably. Even Cinema 4D can do that better.
If you read my above posts, the interface sucks. And now Ive been forced to use it at work because of the Autodesk reliance we have.
Its not enjoyable to use period. I dont know how anyone could actually love this program. perhaps youve only used AutoCAD and only have one platform to compare it to. Ive used so many for so many different purposes and this one to me is a step backwards in an attempt to be more productive. Knowing that there are other programs that allow me to edit my model in 3D makes using Revit frustrating, because the program makes you adhere to what the rules are and not what is sensible and already possible in other programs.
Revit has shoved an entire generation of operators to think within the Revit box. If you think thats not true, then try building a wall thats spherical. This program really tries to dumb you down to building things that are bought off the shelf. This program was designed by the Borg..."You will be assimilated..l.."You must compy....Resistence is futile"
Message 8 of 133
All the other points aside, there are a number of people in this
industry who have developed carpal tunnel syndrome and can no longer use
a regular mouse. Even though I only use it for 0.5% of my navigation,
the steering wheel does have some useful features beyond the standard 3D
Orbit & Pan.
Anthony Mason
http://dailyoccurrence.wordpress.com/
Message 9 of 133
Good question.
It's a process - and theoretically it can be accomplished with just about
anything that can describe a building graphically and with embedded
information.
I saw it being done before Autodesk invented the acronym "BIM", with AutoCAD
R12, Solidworks, Excel, Access, Navisworks and a whole host of other
stuff...
But Revit is a product that is more "BIM oriented" than most.
"Joe Blizzard" wrote in message
news:6360825@discussion.autodesk.com...
> "A+P" wrote
>> they're not BIM
> But then, what is?
Message 10 of 133
Have you ever stepped back and tried to figure out what it is about your
experience that is so different than the thousands of others who would argue
with you about this, and who are successfully putting out projects with
Revit and who wouldn't dream of using anything else?
I once had an architect tell me that "Revit cannot be used to generate
architectural projects". Sitting next to him was another architect who had
been using Revit exclusively for a couple of years with a barely suppressed
smile on his face, the hidden meaning of which was pretty clear to me...
"sbsaint" wrote in message news:6360394@discussion.autodesk.com...
Message 11 of 133
I have news for you. Migrating to BIM isn't easy. It isn't fast. It isn't devoid
of problems and changes in thinking. Anyone who sold you that bill of goods did
not do you a service. But most of us who made the jump wouldn't go back for
anything.
And you will find other apps to be about the same level in terms of frustration.
With all of these BIM authoring tools, you have a learning curve to understand
what it wants and how it works. Like it or not, you need to fit your workflow to
mold around it, not the other way around as with traditional CAD applications.
To do otherwise is analogous to a carpenter trying to use a hammer as a
screwdriver. You can do it, but not without a lot of pain, sparks, and hurt
fingers.
The great thing about Revit is, if you have a preferred modeling tool such as
Solidworks, Rhino, Inventor, 3ds Max, etc, you can usually import that 3D
information and use it within the Revit framework of Families and Conceptual
Massing.
Personally, I think Revit's a blast to use. AutoCAD is still there for what I
may need it for, but that is usually relegated to working with profiles,
manufacturer's content, or when interfacing between the two on a project.
And I think Autodesk hit one out of the park with 2011, in terms of usability.
Some stuff that's missing is still dumb (No tagging of rooms in linked
models...wha?), but I very much appreciate how much they have overhauled and
improved the user interface from 2009.
Matt
matt@stachoni.com
Message 12 of 133
sbsaint
i understand this, however its been 6 months, and I still feel frustrated about the modeling aspect of the program, knowing that what had become common practices with other programs dont apply to Revit. The other thing I dont understand is if I need to import my 3D model into Revit, from another program, what does that say about Revits modeling UI? What justifies the $5k price tag?
I really think that Revit was an application designed to transform an entire generation of "Flatlanders" into the the 3D realm while making it not so intimidating by keeping it semi-familiar to a 2D drafting program. For someone like me. My job requires all stages of design and construction, however, the initial concept images are VERY important to my firm. They will dictate weather or not we have a project or not, regardless if the model changes throughout the DD phase all the way to construction. With this said. Revit is horrible for comming up with concepts because you spend too much time worrying about its over complicated interface, rules, and construction properties to concentrate on design. I can compare it to sketching with ink and mylar.
I think Revit is a poor solution to a great idea.
Message 13 of 133
I do not see anything in your posts where you have had formal training.
That just might be your issue.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Subscribe to the free "The Creative Inventor Magazine now available at:
http://teknigroup.com/CI-Subscribe-Login.asp
Message 14 of 133
Alfredo_Medina
Dennis,
I agree with you, absolutely. That was my first impression, too.
Alfredo Medina
info@planta1.com
Message 15 of 133
I dunno, I've seen some real stunning examples of Revit's modeling capabilities
in SD phases, that means that SOMEONE was able to stretch the program to some
seriously cool limits.
But if easy 3D conceptual modeling is your focus, then use tools which are more
to your taste. Like SketchUP or Rhino.
Then use Revit to advance those models into the BIM process.
Matt
matt@stachoni.com
Message 16 of 133
sbsaint
No I havent had any Revit training as we live on an island in the south pacific. Although you would think that 15years of doing architecture and 3D my experience would amount to something in Revit, instead it amounts to frustration and me constantly asking myself "now why did they decide to do it that way?" $5k peice of software then you need to spend more money to get training. I can tell you with the amount of share ware developers in the world these days giving thier software away for free, overpriced high learning curved platforms like Revit should have alot more brains put into the software and alot less demands of the the users.
I know when I start my own firm, Revit will not be a part of it.
Message 17 of 133
sbsaint
No I havent had any Revit training as we live on an island in the south pacific. I have only been through the tutorial a dozen time which is poorly written i might add. (should I be surprised? it instructs you to find menus as if you already knew where they all are) Although you would think that 15years of doing architecture and 3D my experience would amount to something in Revit, instead it amounts to frustration and me constantly asking myself "now why did they decide to do it that way?" $5k peice of software then you need to spend more money to get training. I can tell you with the amount of share ware developers in the world these days giving thier software away for free, overpriced high learning curved platforms like Revit should have alot more brains put into the software and alot less demands of the the users.
I know when I start my own firm, Revit will not be a part of it. Edited by: sbsaint on Mar 29, 2010 1:59 AM
Message 18 of 133
I hate the interface in Alias Studio and Rhino myself, but of course I
have not had training in those... However, virtually every car built
in the world has a body designed in Alias.
It's not the software's fault.
Message 19 of 133
sbsaint
that says alot about your company, if it doesnt understand how to make something it just buys out the guys that do.
Message 20 of 133
that's not a valid excuse these days. The fact that you are here
precludes you from using your isolation as an excuse for not have formal
training in Revit. IMO of course
Dave - DDP
Acad 2010 and Revit 2010
Win 7 Pro 64 bit
Intel I7-860 @2.8GHz
12GB DDR3 RAM
GeForce GTX260
Administrator Productivity
