Productively I think but on some days it is hard
to tell.
The layout tab is for producing hard copy. The
model tab is for the (in my case) building model. Dimensioning and annotation
is necessary for the hard copy but (and it isn't always true) with the
building model drawn correctly you don't care about the dimensions because you
are only concerned with your portion (plumbing and hvac) as it is relative to
the building model. For the most part, (only rarely these days) the building
model is drawing correctly with out the old manual drafting system of noting
some dimensions as being drawn not to scale.
Model tab or layout tab ( notice "layout tab" not
paperspace ) annotation is not as big a deal as not using the "single
building model" system. The reflected ceiling plan
size=3>, and the millwork plan belong on the floor plan and not as a
separate plan drawn of to the side. The second floor should be drawing over
top of the first floor separated by layer names and not off to the side. It is
a simple concept that most Architects ignor using the phrase "I don't see why
I have to do that.". Engineers as well.
But I digress.
"Charles Prettyman" <
href="mailto:cprettyman@tobinparnes.nospam.com">cprettyman@tobinparnes.nospam.com>
wrote in message
href="news:93E22157DA8BB61E572EDFD381D4517C@in.WebX.maYIadrTaRb">news:93E22157DA8BB61E572EDFD381D......
it s a good digression, becaus I se this all thge
time. I also see model files that have the existing conditions,
Scheme A, Scheme b, and some other half complete alternate all sitting
side by side in model space. Drives me nuts.
"Dave Alexander" <
href="mailto:dalexander@pooleandassociates.bc.ca">dalexander@pooleandassociates.bc.ca>
wrote in message
href="news:19EA794334AC244119603960CFE9C277@in.WebX.maYIadrTaRb">news:19EA794334AC244119603960CFE......
hard to tell.
annotation is necessary for the hard copy but (and it isn't always true)
with the building model drawn correctly you don't care about the dimensions
because you are only concerned with your portion (plumbing and hvac) as it
is relative to the building model. For the most part, (only rarely these
days) the building model is drawing correctly with out the old manual
drafting system of noting some dimensions as being drawn not to
scale.
not paperspace ) annotation is not as big a deal as not using the
"single building model" system. The reflected ceiling plan
face="Times New Roman" size=3>, and the millwork plan belong on the
floor plan and not as a separate plan drawn of to the side. The second floor
should be drawing over top of the first floor separated by layer names and
not off to the side. It is a simple concept that most Architects ignor using
the phrase "I don't see why I have to do that.". Engineers as
well.
But I digress.
"dqueen" <This
href="mailto:dqueen@onealinc.com">dqueen@onealinc.com> wrote in message
href="news:f0cfa92.-1@WebX.maYIadrTaRb">news:f0cfa92.-1@WebX.maYIadrTaRb...
is a very broad question, but there is a reason. My company uses AutoCAD,
Microstation and PDMS. I am in charge of AutoCAD for my company and I am
trying to set goals for where our company should be headed with AutoCad. My
question to anyone is how is AutoCad being used in your companies. Are you
using 3rd party software? If so what?Are you using paper space? If so do you
use it all the time or just in certain cases? What are you doing with 3D and
rendering? What are your clients asking for? Also, we are a multi-office firm
and we share work between office across the WAN. How do you share work? What
problems have you seen? It seems that my company has come to a stand still,
and I need suggestions for the future. There is so much out there, and that
makes it hard to decide which way to go. I am looking for what you are doing
and seen. Anything you would like to share would be
helpful.
"dqueen" <Another
href="news:f0cfa92.32@WebX.maYIadrTaRb">news:f0cfa92.32@WebX.maYIadrTaRb...
question I forgot to ask. Do you charge for cad time and plots, or are they
just added into the multiplier?
"dqueen" <What
href="news:f0cfa92.34@WebX.maYIadrTaRb">news:f0cfa92.34@WebX.maYIadrTaRb...
about cad time? We use an in house program to charge for plots and an house
program that keeps track of cad hours. Just curious how other companies handle
this.
"dqueen" <This
helpful.
