I've been trying to translate an Autocad file into an Microstation file, everything works except those proxy elements. I've tried saving my file from 12 to 14 dxf to dwg and I still lose the information in some cases even before I translate. Is there ANY way to merge these elements right into the file, or is there a way I can drop/explode/export these things in order to lose its properties. Or what about tricking it in some way. Problem is I do not have access to the third party DTM software which is used in the drawing. Any help would be great, thanks
