Does anyone know why the drawing zooms out everytime I select an object to hatch. I have to keep zooming back in, to select the rest of the objects. i am using Autocad 2013
Solved by tedwardspg. Go to Solution.
Set your UCSFOLLOW (0)
This is just another one of those funky malfunctions that we have all come to love. Why else would you want to pay $6K? if you really wanted something that actually works use Microstation.
Select everything in your dwg file. Open a new dwg and paste all the info into that one. Close the original file and save the new on as the old one. The problem should solve itself.
