Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
Global Width of a polyline
26 REPLIES 26
Message 1 of 27
laceysname
174350 Views, 26 Replies
I am very much a beginner with AutoCAD and the majority of what I'm doing at the moment is tracing rubbersheeted paper maps with polylines. My problem is that my polyline tool has somehow gotten set to a global width of 1.9 (approx.) and is so wide that I can't see what I'm tracing. I have to change it back to 0 in the properties box, but by then I can't continue drawing the same polyline. Polyline is the only tool set to such a thick global width, lines and arcs seem fine.
So, I want to figure out how to set the global width for polylines back to 0 as a default.
Many thanks,
Lacey
26 REPLIES 26
Message 2 of 27
in reply to: laceysname
pline
place your first data point
then type W
then set the default width to 0
all future polylines will now use 0
Message 3 of 27
laceysname
Thank you! You have solved my problem! Thank you so much for being generous with someone who obviously is rather ignorant as well. I do nearly all of my work in Illustrator, and AutoCAD is very different.
I have a secondary problem, caused by the first one that maybe you might be able to help with too? I'd be so appreciative. I drew several lines, instead of polylines, because I couldn't see what I was tracing. But, I really need those lines to be joined into polylines. Is there a way to join them together and turn them into a polyline?
Message 4 of 27
PEDIT
select a line
convert it to a PLINE
JOIN all the lines together using PEDIT command
Message 5 of 27
markdoel wrote:
> pline
> then type W
or do it the easy way and set PLINEWID to 0
Dave
DDP
Message 6 of 27
If you have trouble joining line segments, it means the end points are not at the same x,y,z in space. Sometimes its not very obvious, so make sure your end points are at the same point.
Reid
Message 7 of 27
Hey guys!
  1. I have a problem with the global width of a polyline. At first, when I set global width, the polyline became with the width I wanted it to be, but a day after when I opened my .dwg, the width itself was gone - there were only the contours of the polyline with the global width, but the polyline wasn't thick, it was empty. How can I fix this problem? I want to see the polyline with its global width the normal way.. Here is a screenshot of the situation..
Message 8 of 27
Charles_Shade
Is your FILLMODE set to 1?
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Message 9 of 27
in reply to: Charles_Shade
Hi! I don´t know how to make the polylines to appear fill. I paste an image of what I´m saying... Miy fillmode is in 1.
Could anybody help me?
Thanks!
Message 10 of 27
If I'm not wrong, I think I handled the problem with deleting unnessessary things in the drawing. The .dwg file was too heavy and because of that, the global width has gone, and there were only the contours of it. If you haven't anything to delete, try with PURGE command and then PURGE ALL. I hope this can help you!
Message 11 of 27
Thanks for your answer, but it wasn?t that what?s wrong... I?m still trying to figure it out each time that I use that file...
Message 12 of 27
Have you found any solution to the problem?
I also use polyline with global width and have the same thing as mentioned before - there are only contours of the pline, so it looks like rectangles in a row.
Message 13 of 27
Charles_Shade
Set FILLMODE to 1 and REGEN
Message 14 of 27
crees
try "flatten" command.hope this helpSmiley Wink
Message 15 of 27
Message 16 of 27
dany_rochefort
After trying all of these variable changes, i figured out that the problem was the drawing file itself, not the variables.
Solution : Open a new drawing, paste your stuff into it & save as.
Message 17 of 27
C_William_Lee
Did yo try the plinewid system varible?
Message 18 of 27
thank you
Message 19 of 27
diepkhoi90
Pline comand > pick first point > W > 0 > 0 > Pick second point
PS: every > is space
Message 20 of 27
in reply to: diepkhoi90
Thankyou mate..
Administrator Productivity
