CAD Managers
CAD Managers
New Member
laceysname
Message 1 of 15 (30,643 Views)
Global Width of a polyline
30643 Views, 14 Replies
10-16-2009 02:50 AM
I am very much a beginner with AutoCAD and the majority of what I'm doing at the moment is tracing rubbersheeted paper maps with polylines. My problem is that my polyline tool has somehow gotten set to a global width of 1.9 (approx.) and is so wide that I can't see what I'm tracing. I have to change it back to 0 in the properties box, but by then I can't continue drawing the same polyline. Polyline is the only tool set to such a thick global width, lines and arcs seem fine.
So, I want to figure out how to set the global width for polylines back to 0 as a default.
Many thanks,
Lacey
markdoel
Message 2 of 15 (30,642 Views)
Re: Global Width of a polyline
10-16-2009 02:55 AM in reply to: laceysname
pline
place your first data point
then type W
then set the default width to 0
all future polylines will now use 0
New Member
laceysname
Message 3 of 15 (30,641 Views)
10-16-2009 03:06 AM in reply to: laceysname
Thank you! You have solved my problem! Thank you so much for being generous with someone who obviously is rather ignorant as well. I do nearly all of my work in Illustrator, and AutoCAD is very different.
I have a secondary problem, caused by the first one that maybe you might be able to help with too? I'd be so appreciative. I drew several lines, instead of polylines, because I couldn't see what I was tracing. But, I really need those lines to be joined into polylines. Is there a way to join them together and turn them into a polyline?
Active Contributor
morrissette
Message 4 of 15 (30,641 Views)
10-16-2009 04:52 AM in reply to: laceysname
PEDIT
select a line
convert it to a PLINE
JOIN all the lines together using PEDIT command
*Dave Jones
Message 5 of 15 (30,642 Views)
10-16-2009 07:09 AM in reply to: laceysname
markdoel wrote:
> pline
> then type W
or do it the easy way and set PLINEWID to 0
Dave
DDP
Distinguished Contributor
omc-usnr
Message 6 of 15 (30,642 Views)
10-16-2009 11:04 AM in reply to: laceysname
If you have trouble joining line segments, it means the end points are not at the same x,y,z in space. Sometimes its not very obvious, so make sure your end points are at the same point.
Reid
New Member
victoria_yoncheva
Message 7 of 15 (30,467 Views)
01-07-2011 10:20 AM in reply to: omc-usnr
Hey guys!
  1. I have a problem with the global width of a polyline. At first, when I set global width, the polyline became with the width I wanted it to be, but a day after when I opened my .dwg, the width itself was gone - there were only the contours of the polyline with the global width, but the polyline wasn't thick, it was empty. How can I fix this problem? I want to see the polyline with its global width the normal way.. Here is a screenshot of the situation..
Charles_Shade
Message 8 of 15 (30,460 Views)
01-07-2011 11:22 AM in reply to: victoria_yoncheva
Is your FILLMODE set to 1?
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
New Member
LuciaRosarina
Message 9 of 15 (26,487 Views)
07-17-2012 12:36 PM in reply to: Charles_Shade
Hi! I don´t know how to make the polylines to appear fill. I paste an image of what I´m saying... Miy fillmode is in 1.
Could anybody help me?
Thanks!
New Member
victoria_yoncheva
Message 10 of 15 (26,453 Views)
07-19-2012 12:39 AM in reply to: laceysname
If I'm not wrong, I think I handled the problem with deleting unnessessary things in the drawing. The .dwg file was too heavy and because of that, the global width has gone, and there were only the contours of it. If you haven't anything to delete, try with PURGE command and then PURGE ALL. I hope this can help you!
Manufacturing CAD & IT Manager Resource
Additional information for installing, licensing & deploying Inventor, the Product Design Suites and Factory Design Suites.
