Hey Sean;
snip>It's always accurate, no human error on math, quick because you don't
need to think.
Aside from the fact that this post showed up in Cad Manager, rather than
LDT? 🙂
Or were you just looking for helpful comments?
I hope you re-post this gem over there, after receiving said comments - if
that was the intent.
Don Reichle
"The only thing worse
than training your staff,
and having them leave is -
not training your staff,
and having them stay."
Courtesy Graphics Solution Providers
C3D/LDT/CD/SVY-2K6
AMD XP 3200+ 2.2GHz
XPPro 32bit SP2
1GB RAM
Nvidia GeForce4 MX 4000 128MB
"Sean Phelan" wrote in message
news:5130199@discussion.autodesk.com...
Update the inverts or labels on your profiles easy and quck. No more human
error or math needed.
Use Dynamic Labels to automatically calculate your inverts for profiles
drafted.
Process: Draw a line at any elevation across the profile. We will say 180
for this example.
Create a custom label to say INV: {Length/10+180) I have Length/10 to
compensate for my vertical scale and then add 180 to the length to give me
the true invert elevation
Measured Vertical Length = 20
Every 10 feet Vertical is truly 1 foot so that is why the equation is in the
first part of the label.
Example: 20/10 + 180 = 2 +180 = 182
Then, disassociate the label from the line and move to where you want to
have the text placed. If you skip this, the label will always return to the
line it is linked to when updated.
If the profile line work is modified, just extended or trim the line that
the label is associated to and the inverts are automatically recalculated.
It's always accurate, no human error on math, quick because you don't need
to think.
Sean Phelan
"Think outside the box"
