style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"avhg1" <Hi
href="mailto:twturbo@hotmail.com">twturbo@hotmail.com> wrote in message
href="news:f14df2b.-1@WebX.maYIadrTaRb">news:f14df2b.-1@WebX.maYIadrTaRb...
everyone,
My company is in the process of revising our company standards and I wanted
to find out how other civil engineering companies are structuring their files.
There is some debate over the design going in the same file as the sheets. The
way I see it you should have a base file which is xrefed to the sheet file(s).
Also if you could let me know if you have run into problems doing it one way
or the other.
Thanks in advance,
Michael Hall
CAD Manager
Frederick Ward
Associates
"avhg1" <How
href="news:f14df2b.1@WebX.maYIadrTaRb">news:f14df2b.1@WebX.maYIadrTaRb...
large of a company do you work for? With civil engineering, multiple people
work on the same set of drawings, while several designers may need to work in
the base file. The base file is also used in about 3 or 4 different submission
sets. Therefore there will be a collaboration limitation issue with all data
in one file.
Also in the cycle of the project, there may be 2 or 3 design concepts. The
base being xrefed to the sheets makes it easier to transition from
concept/preliminary to construction. We do backups of the designs before major
changes are made as well. It happens frequently that we go back to some part
of an original layout from a backup. The xref makes it a bit easier to bring
those parts back.
I really have a lot of reasons why I propose to do it this way, but need to
have other opinions to present to the powers above.
Here is how we set up our large projects.....
- Facilities Site Design...Street/Utility/Drainage Type.....
- Existing Base (one file, split as needed for project size and workability
- xrefed)
- Proposed Improvements (one file, entities only, worked as model -
xrefed)
- Individual files with layouts for like discipline (text and notes
here in host using xrefs from above, Facilities type projects)
- Individual files one per sheet normally but will allow 3-4 layout
as projects dictates (text and notes here in host using xrefs from above,
Street/Utility/Drainage Type type projects), helps to allow multi-user
workability especially at crunch time.
- Individual detail sheets (could use layouts here, but this
follows form from previous project setups currently in use), helps to allow
multi-user workability especially at crunch time.
Calibration and communication is the key as well as a CAD strategy set
up front. I find that each project we do has some specific circumstance
that will require special treatment. We employ a lead CAD tech to oversee
the project deal with coordination issues between both techs and designers
and keeping unneeded clutter off the network. Yes we zip and archive at
various milestones of the projects. Design concepts are done in the proposed
improvement files and some time have more than one. Once final design is
started previous concepts are deleted (the concept file is still kept for
back up info).
We do a similar setup with site structures.... structure base (xrefed)
used in mech., arch., plumping, hvac., etc.). Structural usually runs independent
but overlay xrefs the mech. base( which is first in the design process
here) to build off of. Because of our treatment plant type work we have
found that total xrefs here make the cad setup to complicated for all to
use efficiently. Communication is the key between all involved.
Ron Meicho
avhg1 wrote:
How large of a company do you work for? With civil
engineering, multiple people work on the same set of drawings, while several
designers may need to work in the base file. The base file is also used
in about 3 or 4 different submission sets. Therefore there will be a collaboration
limitation issue with all data in one file.
The base being xrefed to the sheets makes it easier to transition from
major changes are made as well. It happens frequently that we go back to
some part of an original layout from a backup. The xref makes it a bit
easier to bring those parts back.
need to have other opinions to present to the powers above.
"avhg1" <Hi
everyone,
or the other.
Thanks in advance,
Michael Hall
CAD Manager
Frederick Ward
Associates
My company is in the process of revising our company standards and I wanted to find out how other civil engineering companies are structuring their files. There is some debate over the design going in the same file as the sheets. The way I see it you should have a base file which is xrefed to the sheet file(s). Also if you could let me know if you have run into problems doing it one way or the other.
Thanks in advance,
Michael Hall
>CAD Manager
>Frederick Ward Associates
Thanks in advance,
Michael Hall
> >CAD Manager
