FYI: Information below from my CD burning software indicates that the Joliet
file system limits individual file names to 64 characters, but makes no
mention of total path length. The 256 character limit you noted sounds
familiar though. I've never tried using the UDF format.
· ISO 9660: Select this option if you want to be able to read the CD on
different platforms including DOS, Macintosh, OS/2, Windows, and Unix. Files
and directories recorded to CD based on the ISO 9660 standard must meet the
following (8+3) requirements:
· A file name may not contain more than eight alphanumeric characters and
the underscore symbol [_].
· A file name extension may not contain more than three alphanumeric
characters.
· A directory name may not contain more than eight alphanumeric characters
and the underscore symbol [_].
· Joliet: Select this option if you want to use file names that contain up
to 64 characters in length, including spaces. This is the default option and
is used to record most CDs. Joliet also records the associated DOS-standard
name (8+3 characters) for each file so that the CD may be read on DOS
systems or earlier versions of Windows.
· UDF: Select this option if you want a file system for use with recordable
optical disc technologies, such as DVD. This is especially useful when
burning very large files (greater than 1 GB). The UDF file system allows
greater flexibility than the Joliet or ISO 9660 file system.
Jason
"Charlie Peil"
wrote in message
news:4920850@discussion.autodesk.com...
I believe that CD limit is 256 characters. It's surprisingly easy to
run up against it, too, especially when people get very verbose with the
file name of a letter. Stuff like, "\Letter to Throckmorton Q
Guildersleeve about the Structural Repairs to His Residence at 1623
Dustcough Boulevard - August 12, 2004.doc" Sheesh!
Charlie
Jason wrote:
> If you ever want to burn the project folders to CD-ROM, I believe there is
> a
> path/filename limitation. However, I'm not sure what it is.
