I've moved the original message and attached file over to the
Customer Files group. Please remember that attachments go only to
that group. Copying back the text in the message.
Anne Brown
Manager, Moderator
Autodesk Product Support discussion groups
Discussion Q&A: http://www.autodesk.com/discussion
Subject:
Re: File Locking
Date:
Thu, 4 Jan 2001 08:11:39 -0800
Ron Meicho
Newsgroups:
pn.cadmanager
Two things that I have found that influence the file locking.
First...
Check your external xref setting on each station and (options or
preferences tab), we set it here to "enabled with a copy" to
allow many
users over the network to access the same files without
restricting
access for others. Second... on Novel Network systems change the
"nwfs.sys" file to version 4.1.0.6 on each station (found in
..\system32\netware\___"). There apparently is a conflict with
Autocad
and Novel file handing with the later versions of Novel. The fix
(from
Autodesk and Novel sites a few years back) was to replace this
new file
with this old file. This has worked for us here with V14 on
Win95, WinNT
(not sure with Win98). Win2000 version seams to have this problem
fixed.
Hope this helps.
Ron Meicho
Cad Manager
Gray & Osborne, Inc.
File:nwfs.sy
BlueZoom wrote:
> We also have a similar problem. At a given moment in time every
> CAD user's file is unsaveable as it is being accessed by
> another user. (snip)
