Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
Fatal Error when doing hatch command
1 REPLY 1
Micola10
563 Views, 1 Reply
I have a Fatal Error Message when doing the hatch command and the Auto Cad closes unexpectedly. The message reads as follows Fatal Error: Unhandled Access Violation Reading 0x004c Exception at 10db9554h. Please help! I need to get a project done asap! Thanks Micola
1 REPLY 1
AcadAdamLT
in reply to: Micola10
You should post this under your product specified forum.
for Autocad, post here:
http://forums.autodesk.com/t5/AutoCAD-2013-2014-2015/bd-p/706
Signature, sincerely... //Adam
AutoCad LT 2016
Give Kudos where credit is due, Mark "accepted as solution" if the post solved your question.
Administrator Productivity
