Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
daytonagk
7897 Views, 5 Replies
@extfont2.shx
Dose anyone have @extfont2.shx and dose it work in AutoCAD 05
5 REPLIES 5
in reply to: daytonagk
Go to: http://www.google.com
And do a search for "@extfont2.shx",
and you'll get this:
http://www.cadcorner.ca/textstyles.php
wrote in message news:5856218@discussion.autodesk.com...
daytonagk
I tried that and it said that it was bad. Did not work.
twlincoln
Go to:
Japanese Fonts in AutoCAD Based Products - 2007 and 2008
http://teknigroup.com/support/ACAD/kanji2007.html
Then go to:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=8109007&linkID=9240618
Modify Drawing Codepage Utility
Published date: 2006-Sep-21
Applies to:
AutoCAD® 2007
AutoCAD® 2006
AutoCAD® 2005
AutoCAD® 2004
codepage_tool.exe (exe - 158Kb)
Readme (html - 10Kb)
Drawing files created in AutoCAD® versions older than 2004 and saved in a version of AutoCAD that uses a different language may not properly display text. For example, a drawing created in AutoCAD Japanese 2000 and reopened and saved in AutoCAD English 2002 may display text improperly when opening the saved drawing in AutoCAD Japanese 2000 or AutoCAD 2007.
This DOS utility will change the codepage of drawing files saved in a language other than the language the file was originally created in, allowing text to be displayed correctly.
Tracy Lincoln - TLConsulting
Autodesk Discussion Group Facilitator
vanphu
I dont'n have Font Re: @extfont2.shx. So that You can give me it, don't you?
bags_clark
thanks it works for me! u save my day!..thank you
Administrator Productivity
