Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
Message 1 of 13
tarmbruster
330 Views, 12 Replies
Explode Command
We recently have hired a few temporary CAD drafters out of a local community college. They all have a habit to explode everything, dimensions, mtext, plines, etc. Is there a way to disable the explode command? I have already removed it from the PGP file so they have to type explode out or select it from a menu / toolbar. We are using AutoCAD 2007.
12 REPLIES 12
Message 2 of 13
in reply to: tarmbruster
Type in undefine, then the command. That will disable the command. Type in
redefine to make it work again.
Rick
wrote in message news:5870068@discussion.autodesk.com...
Message 3 of 13
tarmbruster
Will this reset itself every time autocad is launched? Do I have to define this to acaddoc.lsp??
Message 4 of 13
> Thanks
In the words of Mark Kiker...
"Don't let a management problem become a technology problem"
In other words, train these guys or get some new CAD drafters.
R.K. McSwain
http://rkmcswain.blogspot.com
Message 5 of 13
Yes to both questions.
wrote in message news:5870085@discussion.autodesk.com...
Message 6 of 13
Put this reactor in all there startup lisps. Edit it like you want.
(vl-load-com)
(or explodereactor
(setq explodereactor
(vlr-command-reactor
nil
'((:vlr-commandwillstart . cmdstart)
(:vlr-commandended . cmdend)
(:vlr-commandcancelled . cmdcan)
) ;_ end of vlr-command-reactor
) ;_ end of setq
) ;_ end of or
(defun cmdstart (react cmd /)
(setq cmd (strcase (car cmd) t))
(cond
((wcmatch cmd "*explode*")
(alert "\nI will drag you over hot coals\nif you do what I think you're
about to do")
) ;_ end of defun
(defun cmdend (react cmd /)
(cond
(alert "\nIf you exploded any dimensions, mtext, plines you're gone")
) ;_ end of defun
(defun cmdcan (react cmd /)
(cond
(alert "\nSmart move canceling out")
) ;_ end of defun
Message 7 of 13
Smack them across the head and tell them if they do it once more they
are sacked!
mj
> Thanks
Message 8 of 13
Train these guys or get some new CAD drafters: they will never learn from
their mistakes if you don't teach.
Firing works too.
Also contact the school and consult, express your dismay at this lack on
understanding of AutoCAD basics.
AND, most importantly, ask them why they do it: you might be surprised by
the answer.
Dean Saadallah
http://LTisACAD.blogspot.com
Add-on products for LT
http://www.pendean.com/lt
Message 9 of 13
dgorsman
"This was the way we did it at our old job." is a surprisingly common response.
Message 10 of 13
rgorman
I used the undefine method along with an Alert Box saying in effect- "if you want to explode something, check with me so I can dope-slap you"
then they ask "Then how do I 'blah, blah'..."
Then I show them, again...and again... and again...
But at least I don't get a shrapnel drawing.
Message 11 of 13
jackshield
then the status of their position at their current job should become the staus of their position of their previous job, imo
Message 12 of 13
Getting to the root of the problem, vs. the casual dealing of the problem
with Undefine, is how it needs to get solved IMHO.
Unless the OP is in a public library type setting and these are
transients... .
Dean Saadallah
Message 13 of 13
Exploding can be bad in Autocad. But I can't tell you how devastating it can
be in Civil 3D.
wrote in message news:5871632@discussion.autodesk.com...
Administrator Productivity
