James -
Yes, we have had issues with etransmit with Civil 3d for years.
2006/2007 was horrible, but it is better with each release.
Matthew Anderson, PE
James Maeding wrote:
> Its usually one or two of our medium to larger files that are clean, but still have lots of stuff.
> I could do a lot of troubleshooting like you say, but I was wondering if lots of others are seeing this happen also, and
> not saying anything.
> You do have to save 2004 version files to 2007 to get 2009 to work well, and I see a lot of people stumble on that.
> Once past though, its suprising to see etransmit choke.
> I still use it to collect images, but work around it for drawings.
> Its a shame as its a good feature I've always liked.
> cstruckmann <>
> |>i assume one of the xrefs doesn't behave as it should. try the run the etransmit command with slightly different settings. exclude certain xref's, or change some settings (main visual fidelity...). or when running etransmit and it states "processing xx of xx drawings", do you see at which drawings it chokes? look at that drawing very carefully (xref anno scales, xclip, purge and audit, large images)
> James Maeding
> Civil Engineer and Programmer
> jmaeding - at - hunsaker - dotcom
