Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
Enhanced attribute editor
2 REPLIES 2
566 Views, 2 Replies
When I've double clicked in a block would appear a box "Enhanced Attribute Block". But now it doesn't appear anymore. After to double click, the screen freezes and I don't get do no operation more. It is necessary to press ESC to release the software to new operation. How to solve this? Thanks in advance.
2 REPLIES 2
pendean
it's off-screen based on your description: did you recently change from a dual-screen setup, or external monitor, or do something else with your display? It's still there ("freezing symptom), you need to find it.
You could simply 'restore down' but not minimize the AutoCAD program window and see if you can spot it hiding behind something near the edges of your monitor.
in reply to: pendean
Thank you so much. It seemed that problem was exactly this. I've changed recently my display output.
Best Regards.
Hebert Aguiar
HG Desenhos e Projetos
T 31-3662-1574
C 31-9124-6534
Administrator Productivity
