Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
DWF Drivers: Which one to use?
4 REPLIES 4
530 Views, 4 Replies
When adding a plotter for 2010 there are multiple choices for setting up a DWF PC3. Which one would you choose?
4 REPLIES 4
The program already comes with a predefined DWF driver in PLOT: are you
needing to add more, or replace a deleted option?
DWF6 and DWFx that is...
Dean Saadallah
http://LTisACAD.blogspot.com
Just wondering if there is a difference between the DWF6 and the DWFx driver. Do you use the out of the box version? Have you had any trouble filtering out the ISO full bleed B1(707.00x10000.00MM) sheet?
this is a bug and has been reported.
all the other sheet sizes filter out ok, its only the B1 bleed sheet which will keep poping back into your list
cheers
mark
DWFx is the newer version: Win7 and Vista can read DWFx with no need to
install a viewer I believe.
DWF6 is the older format and most common between professional AutoCAD users.
Dean Saadallah
Administrator Productivity
