I have six websites driven by this lame technology 🙂 the ASP pages on
those sites are bullet proof and fast.
While ASP.net also works just fine, it is not required to connect with
either MS access or full SQL. The big difference to most users there is the
size of the data storage, not the filestore.
If you want to be on the leading edge of the technology, that's fine but you
can't knock what works either.
ASP or ASP.net, they both work
Dennis Jeffrey, AICE, MICE
260-312-6188
Instructor/Author/Sr. App Engr.
Inventor 11 Professional SP2, MDT 2007 SP1
HP Pavillion Zv5000 (Modified)
Geforce Go 440, Driver: .8185, 2GB RAM
XP Pro SP2, Windows Classic Theme
http://www.design-excellence.com
"clintonG" wrote in message
news:5555732@discussion.autodesk.com...
I recommend using web development for the user interface because it can and
will indeed reduce costs but I don't recommend using Active Server Pages
(ASP) which are an outdated and lame technology in comparison to ASP.NET.
I would also not recommend using the Jet database either as it has been
discontinued noting Access is not the database, it is in effect nothing more
than a user interface builder with query language support including related
features to enable Access to be used to develop desktop applications which
it has been used to do very well over the years.
The era of Access/Jet is basically over. I suspect Microsoft will soon
re-engineer Access to extend its life by improving its use as a front-end to
real SQL databases which it supports now marginally. I think it will still
take another two years when I think Jet will finally be retired once and for
all as Microsoft has just done with FoxPro just this month I recall. Well, I
read in passing the FoxPro developers are begging for continuance but I
don't see much chance of that. Like ASP, FoxPro is simply too outdated in
comparison to contemporary tools and even Microsoft can't afford to continue
supporting these buggy whips like Jet and FoxPro.
The preferred solution for those just getting started on the Windows
platform is the use of SQL Server Express using ASP.NET to develop the user
interface, the data access layer, and the development and enforcement of
business rules to manage who can and who can not access webpages and data
right down to controlling parts of the page using ASP.NET Membership, Roles
and Profiles.
Active Server Pages are so lame in comparison there isn't much comparison
anymore. Microsoft has refined its database strategy so databases and code
developed with SQL Server Express can be reused with SQL Server 2005 and
those releases of SQL Server to follow. There is also a free SQL Server
Express Manager used to create and manage the SQL databases.
Later this year Microsoft will release LINQ (Language Integrated Query)
which enables web developers to do all the database code and web application
code in the same file using the same language used with ASP.NET which is a
significant productivity enhancement. Its well worth every bit of struggle
and hard work to adopt and learn SQL.
Finally, .NET 3.0 has recently been released and CAD Managers are going to
start hearing more and more about one aspect of 3.0 known as Windows
Workflow Foundation which enables business rules to be automated using
ASP.NET. A transmittal can be routed using workflow rules which control who
gets what and when for example. Just imagine this; on the basis of a
transmittal one partner could have a set of drawings zipped up and
transmitted using FTP and another partner a whole different set of drawings
or other documents. All automated using ASP.NET.
There's so much going on hardly anybody can keep up with it but once having
been coding with ASP.NET I'd have to be drugged and dragged kicking and
screaming to go back to ASP.
Many people are going to be doing just fine with what they have developed
using Access/JEt or even those using the most populat "database" called
"Excel" 😉 but what of those who find themselves with their most valuable
assets thrown mumbo jumbo into a shoebox like Excel or the file system. What
then? Web development is the answer...
<%= Clinton Gallagher
NET csgallagher AT metromilwaukee.com
URL http://clintongallagher.metromilwaukee.com/
wrote in message news:5554815@discussion.autodesk.com...
walked into a mess, got a jumbled directory of drawings, no database. i
need to create database using microsoft access, but not skilled in creating
such, only been an end user to now. does anyone have any such templates they
could pass along to get me jump statred?
