CAD Managers
CAD Managers
Active Member
0 Kudos
Post 1 of 11
Custom properties on a sheet template.
337 Views, 10 Replies
03-20-2014 05:45 AM
I am currently in the process of updating a title block on a sheet template. I am trying to make a specific attribute on the title block appear in a second location on the title block but copy pasting the attribute messed up the fields.
I am trying to fix the original field and then duplicate it, the original field didn't have a category in the feild dialogue box it just came up as *unknown* and the field expression was
%<\AcSm Database("file location").Component("gB656EE1A-0FB1-43A4-B7F2-42E590AF4EBF")
.Title \href "Q:\P900-999 file location.
If anyone can help me figure out how to recreate this or even how to use custom feilds on a sheet template it would help ALOT, thankyou.
*Expert Elite*
485 Kudos
Post 2 of 11
Re: Custom properties on a sheet template.
03-20-2014 05:58 AM in reply to: 13041995
First off. Is Q:\P900-999 the correct file location and is it available on the network?
Allen
Active Member
0 Kudos
Post 3 of 11
03-20-2014 06:00 AM in reply to: AllenJessup
Yepp its the correct location and it working for other locations in the same titleblock.
*Expert Elite*
485 Kudos
Post 4 of 11
03-20-2014 06:40 AM in reply to: 13041995
I've looked around and can't find anything on the rest of the expression. We don't use document links so I don't have experience with them. I know when I copy a field with an Object reference I have to edit the field an select an object.
Your best bet may be to recreate the field from scratch.
Allen
Active Member
0 Kudos
Post 5 of 11
03-20-2014 06:58 AM in reply to: AllenJessup
Thankyou
Is there a way to create a custom feild without using sheet set manager? since i am making a template i cant use SSM
*Expert Elite*
485 Kudos
Post 6 of 11
03-20-2014 07:06 AM in reply to: 13041995
You can create fields in Mtext, Text and Tables. Usually Insert Field (ctrl-f) is available on the rt-clk menu after you start creating the text.
Allen
Active Member
0 Kudos
Post 7 of 11
03-20-2014 07:11 AM in reply to: AllenJessup
Sorry i wasnt clear in my question, how can i insert a feild that links to custom properties of the sheet.
17 Kudos
Post 8 of 11
03-20-2014 07:14 AM in reply to: 13041995
what I usually do is I create a dummy sheet set, modify the titleblock as needed (fields, etc) in a drawing within that sheet set, then save that drawing as a dwt on our network.
Active Member
0 Kudos
Post 9 of 11
03-20-2014 07:17 AM in reply to: pkolarik
Thankyou so much
Sorry i have one last question, in terms of duplicating the attributes so the same information appears in two places with one date entry, would copy pasting to the job or do i create a seperate attribute and link it to the same feild.
*Expert Elite*
485 Kudos
Post 10 of 11
03-20-2014 07:26 AM in reply to: 13041995
We don't use sheet sets. So I'm not sure. I do see a category for them when I create a field in Mtext.
Allen
Post to the Community
New Post
Announcements
Manufacturing CAD & IT Manager Resource
Additional information for installing, licensing & deploying Inventor, the Product Design Suites and Factory Design Suites.
