Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
custom linetype question
4 REPLIES 4
ebattle
387 Views, 4 Replies
Good day all,
I've been trying to create a linetype that will represent a pavement marking. It should consist of a 10' line with a 20' gap.
I managed to make one but in order for in to show up correctly in my viewport I have to set the linetype scale of that line to whatever my viewport scale is going to be, which causes issues when placing the design into a viewport with a different scale.
Is there a way to create the line so that I can just leave the linetype scale at one and it still break correctly in each vport?
this is the code I had been using.
*BWLL-BTD,10 foot line 20 foot space 1:1
A,10,-20
Thanks for your input,
ervin
4 REPLIES 4
in reply to: ebattle
Read up on PSLTSCALE.
ebattle
That works, but if I change my psltscale to zero linetypes like hidden2 don't show up correctly.
ACADuser
Create a different linetype definition for every scale that you use. Then create a layer for each scale and copy the elements to each layer. You will have duplicate lines but you could then control visibility by viewport depending on the scale.
ACADuser
Civil 3D 2018, Raster Design 2018
Windows 7 Enterprise
Dell Precision 5810 Workstation
Intel Xeon E5-1630 v3 @ 3.70GHz
32GB RAM, NVIDIA Quadro K2200 4 GB GDDR5
DUAL 27" Dell UltraSharp U2713HM
ebattle
Thanks for the suggestion.
e
Administrator Productivity
