CAD Managers
CAD Managers
lsimms1
Message 11 of 16 (917 Views)
Re: CTB Usage in Multi-user Environment
10-24-2012 10:03 AM in reply to: b-man
We still use ctb.
We have our standard ctb file(s) based on city standards. If we want to change the way something plots, we x-ref into another drawing and change the color of the layer to the appropriate pen.
This leave the original drawing as it "should" be, but plots as required for that job/drawing sheet.
Distinguished Contributor
pkolarik
Message 12 of 16 (909 Views)
10-25-2012 06:06 AM in reply to: pendean
Yes Dean.... the OP was read. You may have noticed when you breezed thru it that he said not only does one group want to have yellow be different lineweights, but that another group wants to have yellow always be the same lineweight.
He then went on to ask for opinions from *both* sides of this issue.
troma
Message 13 of 16 (853 Views)
10-30-2012 08:45 AM in reply to: pkolarik
Is it possibe to set a layer to plot with a screening using STB?
Credit where credit is due! Give kudos or accept as solution whenever you can.
leothebuilder
Message 14 of 16 (765 Views)
11-20-2012 08:16 AM in reply to: lsimms1
Yes, using STB plot styles you can set layers to screen.
You can also use "transparency".
Valued Mentor
mdhutchinson
Message 15 of 16 (399 Views)
04-03-2013 11:47 PM in reply to: leothebuilder
Any one here use CTB with fully 3d drawings?
Also hidden plot styles?
How? We've found hidden plot style does not respect CTB control. All settings to control line weight whether by layer or by style (dim style based line weight))  or CTB seem to default to LWDEFAULT setting.
 Is any one seeing this also? Any solutions?
Hammer.john.j
Message 16 of 16 (342 Views)
04-23-2013 01:37 PM in reply to: mdhutchinson
If you have a color set to a lineweight in the ctb instead of "useobjectlineweight" it will ALWAYS over ride a lineweight applied to an object... if the color used for the object is set in the ctb to useobjectlineweight you shouldn't have problems...
that is why i institute a system that limits the use of like 15-20 colors out of 255 in CTB setups such that you have access to "colors" and other "lineweights" even "blacks" as long as the ctb color is set to pen 7, and useobjectlineweight.
John Hammer, LA
Dell Precision T3500 - Xenon W3550 @ 3.07 (4 core)
Ram @ 12Gb
64bit Win7 Pro
Samsung SSD
NVIDIA Quadro 2000 - Dual Monitors
Cat 6 network with GlobalScape Avail Agent - WAFS
Infrastructure Design Suite Premium and Civil 3D 2012 & 2014
Manufacturing CAD & IT Manager Resource
Additional information for installing, licensing & deploying Inventor, the Product Design Suites and Factory Design Suites.
