I think this feature is already in Land 2005... but I could be wrong. Maybe
it's in Autodesk Survey 2005, the Land add-on.
I have a pulldown menu named Carlson Connect and one of the options is to
import .CRD files. Take a look at Carlson Connect > Carlson Software >
Import Carlson CRD points. This will bring the points into Land as points.
HTH,
Jeff
"mdrabic" wrote in message
news:32997512.1104412890207.JavaMail.jive@jiveforum2.autodesk.com...
> Does anyone know of a program other than (now Carlson) CG Survey that will
> convert .crd files into .asc files. We have a ton of .crd files that need
> to be converted and doing them one by one will take a long time. Or does
> anyone know of a way to directly import these .crd files into Land Desktop
> as points...i've have been in contact with autodesk about this and they
> still have no solution. Is there a solution? Also, does anyone know of a
> more compatable data collection DOS based software to use instead of CG
> Field +?
