Jim,
>You can save a dwg directly to a dgn from within V8
Yep.. in this case the client has microstation and we have autocad and
no microstation, therefore, I can't save a dwg to dgn. Their
requirement for "electronic deliverables" is dgn format!
>or you can use AutoCAD Map and convert (not as clean)
OK, thanks for the info. But, don't have Map!
>Can't imagine why your client is making you jump through these hoops - they
>have all the tools they need to do this in-house-unless they are actually
>wanting you to convert your files over to a pre-existing CAD std that was
>developed for Microstation. Then it starts to get more problematic.....
I'm in process of getting the client specs for "electronic
deliverables" but I was told that they would not accept "dwgs" that it
is our responsibility to translate from dwg to dgn. Could be because
this is a military project. I looked at dgnlink and cats conversion
software on the internet and they range from approx $1000 - $3000.
Other option may be to use a service bureau for conversion.
Tom
Thomas E. Momeyer, AIA, CCS
