Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
Changing multiple XREF file locations
2 REPLIES 2
stephen.clifton
1549 Views, 2 Replies
Will soon be changing the xref location dir for new and upgraded office network.  The problem being that l have 100's of files with some exceeding 200 - 300 xref's. Is there a way to change the paths via a multiple option rather than completing this method one by one. i.e;
  1. xref
  2. (select xref)
  3. @ found at; browse for select path
  4. find xref and open
Any help would be appreciated
Geoff
2 REPLIES 2
pendean
in reply to: stephen.clifton
Reference Manager is an external app you install with AutoCAD that will do just that.
stephen.clifton
in reply to: pendean
Thanks Dean, you've saved me a couple days of work.
I really appreciate your time and quick response.  I had already installed this as part of 2011 but like most new products and additions, find it hard to spend the time to go through and see what there all about.
Cheers
Geoff Newport
Australia
Administrator Productivity
