Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
Changes to standard PROFILE after distribution?
10 REPLIES 10
Message 1 of 11
161 Views, 10 Replies
How do you handle this in your office?
Once a standard autocad PROFILE has been distributed to each machine in
the office, what is the most eloquent way to make a change in the
Profile (settings stored in the registry) without actually having to
visit each machine to reload it ?
10 REPLIES 10
Message 2 of 11
cprettyman
I worked with my IT guys to put together a login script that merges a reg file at logon for everyone. I spent some time making, and testing changes in that file, and then had them activate the script, and voila, 90% of the office was updated at the next logon. The other 10% were the power users and malcontents who were not using the default profile. (ironic, isn't it, that my best and my worst users often have similar issues)
Message 3 of 11
You can also use WSH (WindowsScriptHost) to manipulate the registry. The
nice thing is, you can read the registry to see what profile is current, then
make the required changes to that profile directly, addressing those malcontents
Best,
Gordon
Message 4 of 11
cprettyman
Actually, I think you'd need to just amke the same change in each profile - I asked the IT guys about doing that, but tehy don't know WSH well enough (and neither do I).
Message 5 of 11
(and neither do I).
Yes, with WSH you could iterate thru all the profiles on the machine, and
make edits to each. The basics are pretty easy, just VBA with a few things
removed, but the iteration part I am not sure about. Of course iteration and
recursion kills me in Lisp too 😉
Best,
Gordon
Message 6 of 11
This thread is also being covered in customization
as well, I made the suggestion he control variables he needs to maintain via
VBA.  Load a standard macro that will run everytime AutoCAD is opened and
changes the necessary paths/variables/etc.  No mucking with the
registry.  It changes for whatever user logs on and runs AutoCAD, just gets
loaded with the custom menus and routines.
There's my $.0134453 🙂
Best,
Gordon
Message 7 of 11
cprettyman
This would work for me - especially if I could store the variables in a read only network location, so that I could update it in one place at my convenience - Are tehre examples posted int he customization NG (I'll go look, but if you know of good ones, point me int he right direction).
Message 8 of 11
I haven't quite gotten that far with my
setup.  I was thinking of using a read only INI or TXT file with the
settings.  For now, I simply have a section of my VBA code that sets all
the variables I check against, much as I would with a INI or TXT
file.
This
Message 9 of 11
customization as well, I made the suggestion he control variables he needs to
maintain via VBA.  Load a standard macro that will run everytime AutoCAD
is opened and changes the necessary paths/variables/etc.  No mucking with
the registry.  It changes for whatever user logs on and runs AutoCAD,
just gets loaded with the custom menus and routines.
Did you find a setting in Acad to control
ActiveAssistence? I could find only two ways to turn it off, manually via the
system trey, and via the registry. That is what pushed me into WSH (we had 30
machines to setup, and NOBODY wanted ActiveAssistance). Once I got it working, I
just kept using it for other things as well. BTW, you can have VLisp execute a
WSH script, so you could build the script and then run it from within AutoCAD.
You might even be able to tell the script how it started, so it could handle
things differently depending on Acad being active or not.
Best,
Gordon
Message 10 of 11
Charles,
I currently store all of my standard Profile data in an INI file,
which is read by a VisualLISP application that interprets it and
modifies AutoCAD's Preferences object, then writes the profile out to
a user's home folder for safekeeping.
Using DOSLib, reading an INI file is really easy.
Matt
mstachoni@comcast.net
mstachoni@bhhtait.com
On Thu, 24 Jul 2003 07:38:25 -0700, c.prettyman
Message 11 of 11
I may have to dig a little deeper, but no.
It looks as though it's run as a separate executable, not controlled by
AutoCAD.
to maintain via VBA.  Load a standard macro that will run everytime
AutoCAD is opened and changes the necessary paths/variables/etc.  No
mucking with the registry.  It changes for whatever user logs on and
runs AutoCAD, just gets loaded with the custom menus and
routines.
I just kept using it for other things as well. BTW, you can have VLisp execute
a WSH script, so you could build the script and then run it from within
AutoCAD. You might even be able to tell the script how it started, so it could
handle things differently depending on Acad being active or not.
Best,
size=2>Gordon
Administrator Productivity
