CAD Managers
CAD Managers
Active Member
davidlewis5275
Message 1 of 10 (757 Views)
Change Licpath.lic via vbscript
757 Views, 9 Replies
02-28-2012 09:14 AM
I have about a dozen autodesk products where I need to change the Licpath.lic.
According to Autodesk ADSKFLEX_LICENSE_FILE will not work with a redundant server setup so I need to replace the licpath.lic on every product.
Does anyone have a vbs script that they could share that copies over a new Licpath.lic file?
I would be using this as a machine script at bootup, not a login script.
TravisNave
Message 2 of 10 (752 Views)
Re: Change Licpath.lic via vbscript
02-28-2012 10:20 AM in reply to: davidlewis5275
I recommend never using the redundant model because it does not work as intended and the only redundancy is the amount of work required to implement and keep it running.  Now that I am off my soap box, you can find a suitable solution here:
http://forums.autodesk.com/t5/Installation-Licensing/problem-changing-licencing-servers/td-p/2668660
Active Member
davidlewis5275
Message 3 of 10 (746 Views)
02-28-2012 10:42 AM in reply to: TravisNave
With a mixture of windows 7 and xp I want to avoid the registry. Things are setup with licpath now and I just need code to replace those files
TravisNave
Message 4 of 10 (744 Views)
02-28-2012 10:51 AM in reply to: davidlewis5275
Since the file structure will be the same, you could just run a simple DOS batch file to do a copy overwrite from a shared location with the modified LICPATH.LIC to the Autodesk application root folder.
Active Member
davidlewis5275
Message 5 of 10 (742 Views)
02-28-2012 10:54 AM in reply to: TravisNave
If dos would work I would not be posting Windows 7 with the UAC will not allow writing to the c:\program files locations
TravisNave
Message 6 of 10 (740 Views)
02-28-2012 10:57 AM in reply to: davidlewis5275
You need to disable UAC.  It serves no purpose but to make your life miserable.  Definitely doesn't need to be enabled in an enterprise setting.  You have group policies for that.  I never understood why people insist on handicapping themselves and then try to explain ways around the very obstacles they set for themselves.  If you're looking for a method to circumvent UAC, then UAC really isn't serving its purpose.  If you can circumvent it, anyone can.  Just turn it off.
Active Member
davidlewis5275
Message 7 of 10 (737 Views)
02-28-2012 11:08 AM in reply to: TravisNave
We are arguing about a non point here I just need vbs code I figured other cad managers had the code already I will ask in a Microsoft group instead Btw the it department sets UAC, not the cad managers
TravisNave
Message 8 of 10 (735 Views)
02-28-2012 11:15 AM in reply to: davidlewis5275
I wish you luck.  I can attest that as part of IT, I would never set UAC on my users.  Perhaps your IT can make an exception for your engineers, or at the very least, in the short term while you enlist your necessary changes.
Active Member
davidlewis5275
Message 9 of 10 (733 Views)
02-28-2012 11:41 AM in reply to: TravisNave
We are probably going to turn it off but again non issue
I want vbs, its more transparent to the users.
TravisNave
Message 10 of 10 (730 Views)
02-28-2012 11:55 AM in reply to: davidlewis5275
I can respect that.  The IT guy in me says to just use the login script... but you probably really don't have access to that!  :smileyvery-happy:
Manufacturing CAD & IT Manager Resource
Additional information for installing, licensing & deploying Inventor, the Product Design Suites and Factory Design Suites.
